Results 11 to 20 of 26
Thread: FAQ: Fooling pc to think a keyboard is plugged in.
  1. #11
    Mar 2006
    Hi guys,
    thank you for helping, I just want to make sure, what I do is right.
    So, all I need is a connector (Ps2 style connector (newer)), then I need to use 10k resistor, to soldier between the wire of pin 3 and pin 4 for the keyboard connector right ? After that just plug in the other side of the keyboard on motherboard right ? thank you.
  2. #12
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Umm, right. But if you have to ask the same question three times to make sure that you have figured out how to bridge two wires with a resistor, I'd recommend that you not only don't do it, but seriously reconsider whether you're equipped to install a PC in your car.
    There are lots more difficult and fuzzy things about installing a car PC than this three step, very clear tutorial.
    Want to:
  3. #13
    Jul 2006
    Would this also work with a ps2 mouse?
  4. #14
    FLAC FC3S's Avatar
    Jul 2006
    Seoul, Korea
    why would you need to fake the computer into thinking a mouse is plugged in?
    what purpose would that serve...?
  5. #15
    Elsewhere
    Quote Originally Posted by LYHTSPD View Post
    No.
    How about the Wiki?
  6. #16
    Raw Wave shotgunefx's Avatar
    Apr 2005
    Boston, MA
    A PS/2 mouse works similar to a ps/2 keyboard, but sends a CTRL-M so that it knows it's a mouse IIRC.
    Take a read at this thread
  7. #17
    Jul 2006
    Quote Originally Posted by FC3S View Post
    Oh, it is for a completly different application. Nothing at all to do with carPC.
  8. #18
    Oct 2006
    I've tried twisting the stripped wires from the keyboard around both ends of the resistor (1/4W, 10,000 ohm) but it doesn't work.
    Does it actually NEED to be soddered? I've tried just putting it in the PS/2 slot of the motherboard, and it still doesn't work..
    can anyone give me a link to the kind of resistors used here, so I can make sure I'm using the right kind?
    Mine are Brown, Black, Orange and Gold (color stripes)
  9. #19
    Jul 2006
    I honestly don't see how the OP's hardwire method will work with a PS/2 keyboard. From what I have read, a PS/2 keyboard with talk with the motherboad controller back and forth to and uses an initilization sequence to confirm the existince of each other. I am not sure that just using a resistor to drop the voltage across the +5v line will do anything (maybe for an AT style keyboard). My advice is to basically get an old PS/2 keyboard, tear the driver chip out of it and solder it the PS/2 cord. I had to do this with a mouse for my problem in my earlier post and it works like a charm.
  10. #20
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Quote Originally Posted by Termina View Post
    Here is a 10k ohm resisitor:
    Brown, black, orange, gold
    Are you sure you have the right wires to the right pins? Did you use a multimeter to confirm you have the proper wires or did you guess?
    Want to:
  1. Replies: 2
    Last Post: 06-19-2005, 04:18 AM
  2. For Sale for all you aussies. Complete mp3 car pc
    By Holden__V8 in forum Classified Archive
    Last Post: 04-09-2005, 06:30 AM
  3. mac keyboard with a PC?
    By Machs_FueL in forum General Hardware Discussion
    Last Post: 01-11-2002, 03:12 PM
  4. no box pc??!! built into keyboard!
    By RaZor in forum General Hardware Discussion
    Last Post: 12-08-2001, 05:58 AM
  5. Disabling BIOS keyboard error?
    By Squeezer in forum General Hardware Discussion
    Last Post: 02-02-2001, 09:29 AM
