Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: FAQ: Fooling pc to think a keyboard is plugged in.
    Takes it in the Rear kevinlekiller's Avatar
    Dec 1969
    Where the penguins and polar bears live.
    I was helping ooopseyesharted , and I told him that if you have no keyboard the computer might give an error. Anyways lets gon on with the tut. :
    Theres 2 ways to get the computer to boot.
    1) The soft method (might not always work).
    2) The hard method (always works).
    1) The soft method: (soft = software)
    a) Go in your computer bios settings.
    *(on most computers: press delete when you first boot the computer)
    **(On computers such as dell , compaq , hp , etc... , its usualy one of the F keys).
    b) Look for: "halt on keyboard error" Or something similar. - Set it to False ( or no).
    If you have this option : "halt on all errors" or something similar - Set it to False (or no.)
    If you have none of these options move to the hard method
    ..c) On some computers enabling Quick boot in the bios menu will bypass the keyboard check.
    2) The hard method (hard = hardware)
    For this mod you need a 10k ohm resistor (carbon film). (you can get them at radio shack).
    AT style connector(older):
    There are 3 ways you can do this:
    1. get a old keyboard and cut the AT plug.
    Strip the wires , with a tester check wich pins go with wich wires. We need the wires for pin 4 and 5(check the picture above).
    Solder the resistor between the 2 wires you found.(solder the resistor in any direction it doesnt matter).
    2. Insert the resistor on the motherboard connector between pins 4 and 5 and hot glue it in place.
    Or 3. With a tester find were pins 4 and 5 lead on the motherboard. And solder the resistor there.
    Ps2 style connector (newer):
    1. get a ps2 keyboard and cut the ps2 plug.
    Strip the wires , with a tester check wich pins go with wich wires. We need the wires for pin 3 and 4(check the picture above).
    2. Insert the resistor on the motherboard connector between pins 3 and 4 and hot glue it in place.
    Or 3. With a tester find were pins 3 and 4 lead on the motherboard. And solder the resistor there.
    This concludes the tutorial.
    Thanks to google for the info and pictures
    Version 1.1
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Thanks for the FAQ, Kevin. Added to the FAQ to the FAQ's.
    Want to:
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    Or better yet if you going to waste a KB just open it and extract the PCB (brain) and forget about the buttons, housing etc, connect it like a regular KB (hide the brain somewhere in the car)
    BTW finally I see that the monkey (kev) is giving back to the community. J/k
    Thanatos.
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
    Raw Wave tj!2k4's Avatar
    Oct 2004
    what about just bending the resistor into a U-shape and inserting it into the required pin receptacles on the motherboard and hot-glue-ing/taping it into place so it won't fall out?
    then there's no need to waste a perfectly good keyboard.
    Dec 1969
    Quote Originally Posted by tj!2k4
    EDITEd-------------
    I miss read my own post , but its already there , its just I didnt write it well. Let me write it back.
    Thanks.
    Nov 2004
    Well that idea is better than solder something to the mobo, but like here in miami KB are $3.00
    Thanatos.
    Nissan Aux-in MOD
    Dec 1969
    Quote Originally Posted by thanatos106
    Thanatos.
    Resistor - 5 cents.
    Hotglue gun + hot glue 1 $
    Installing it all - Priceless
    Mar 2006
    Quote Originally Posted by kevinlekiller
    Version 1.1
    hi,
    can you please give me more detail, like step by step if you have a picture, it wil be awesome, sorry I am kinda noob. I'd like to do the hard method, since my computer doesn't has "halt on keyboard error" or something similar.
    Can you tell me, what kind of stuff I need, and how I am gonna to do it, thanks for helping.
    Oct 2004
    Quote Originally Posted by shinjetko
    hi,
    Call me crazy, but it would appear that the instructions clearly state what is required
    and what needs to be done:
    OR
    OR
    There were even pictures!
    What is the problem??
    No offense, but if you're having trouble following these instructions, maybe you need to look into a different hobby.
    Dec 1969
    You dont need a keyboard, you can buy an extension , or use a broken keyboard that dont work in a pc no more.
    And the reason why you would use just the cable and not the whole keyboard(pcb) is to save space.
  1. Replies: 2
    Last Post: 06-19-2005, 04:18 AM
  2. For Sale for all you aussies. Complete mp3 car pc
    By Holden__V8 in forum Classified Archive
    Last Post: 04-09-2005, 06:30 AM
  3. mac keyboard with a PC?
    By Machs_FueL in forum General Hardware Discussion
    Last Post: 01-11-2002, 03:12 PM
  4. no box pc??!! built into keyboard!
    By RaZor in forum General Hardware Discussion
    Last Post: 12-08-2001, 05:58 AM
  5. Disabling BIOS keyboard error?
    By Squeezer in forum General Hardware Discussion
    Last Post: 02-02-2001, 09:29 AM
