Page 2 of 10 FirstFirst 12345678910 LastLast
Results 11 to 20 of 95
Thread: FAQ: Connecting your soundcard to a Volkswagen Monsoon Amp
  1. #11
    Mar 2006
    quick question: where did you get the box, where in canada can i get a similar one, and how much?
  2. #12
    Maximum Bitrate kbyrd's Avatar
    Nov 2003
    Northern Arizona
    Quote Originally Posted by evandude
    Just a thought... but you should be able to achieve the same +6v offset using capacitors instead of the bulky, expensive ground-loop isolator.
    In fact, the original circuit I installed did use caps, but I like the isolator ($15 at Radio shack) better and I actually had some whine the caps didn't get rid off.
    My worklog.
    Status: VM GTI sold, got out of the CarPC tinkering hobby, but I still think about getting back in.
  3. #13
    Nov 2003
    Northern Arizona
    Quote Originally Posted by peterbrowne
    The black box is just a plastic box from Fry's Electronics. They're local to California and maybe Arizona and Nevada. But, it's a black project box. Most electronics stores (like radio shack) should carry them. If you're really stuck, I'll send one to you, but you'd probably pay more in shipping than the box cost.
    My worklog.
  4. #14
    Apr 2006
    Hey thanks for the DIY write up. 3 quick questions.
    Can the existing monsoon harness be tapped into to?
    Did you splice the wires together L and R or separate them with RCA Y cable?
    Do you need a heat sink for this setup?
  5. #15
    Mar 2006
    Pa
    I agree... awesome write up. I am in the beginning stages of getting everything I need for my puter. Once that is accomplished, I will be visiting this thread again!
    My Shadow used to look like this. She's better now!
  6. #16
    Well, He asked for it. WebDog's Avatar
    Los Angeles, CA (West LA)
    Quote Originally Posted by wzcunningham
    Yes but then you cant easily revert back to stock... its better to make a new harness...
    The left side of the car is connected to the left and the right is connected to the right, no y spliter needed.
    I havent been using a heatsink and have had no problems with my setup.
    1990 Jeep Cherokee
    2000 VW Golf TDI 4dr
    2005 VW GTI MKIV - SOLD
  7. #17
    Apr 2006
    thanks for the reply. i plan on using t-taps on the monsoon harness so it just as easily goes back to stock and i'll save $20.
  8. #18
    Mar 2006
    Pa
    Talking
    Good luck, But I might just say spend the xtra $20.
    Thanks to you guys for posting this up and going through all the mess so we/I do not have to!!!! I am gonna be picking up these parts soon and testing it out with a simple portable player or laptop before implementing the rest.
    I am sure I will be in touch or have questions when I see a waff of smoke and nothing works anymore. Dang VW gnomes.
  9. #19
    Mar 2005
    Im planning on using this to connect to my monsoon amp. I am going to be using two of the three outputs (one for front left and right, and one for back left and right). I figure I will have better fade/balance control doing it this way. How do I go about injecting the power into the system now, because there will be two lines and four RCA's instead of the one line and two RCA's? I appreciate the help. Thanks.
  10. #20
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    That thing has been a preorder item for over a year now.
    Want to:
  1. Need help building VW Monsoon amp input
    By kbyrd in forum Car Audio
    Last Post: 02-23-2009, 03:13 PM
  2. Couple of questions about the monsoon system
    By Bugbyte in forum Car Audio
    Last Post: 07-07-2005, 08:47 PM
  3. Replies: 4
    Last Post: 05-17-2005, 05:17 AM
  4. Replies: 20
    Last Post: 10-31-2004, 10:53 PM
  5. Any VW MKIV owners run their PC direct to the Monsoon amp?
    By Semler in forum General Hardware Discussion
    Last Post: 04-02-2004, 04:04 PM
