Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: Hard Drive Issues in a Vehicle Computer
  1. #21
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Drives are cheap, CarPC's don't usually have unrecoverable data on them.
    Just install, bolt it down and run it.
    Want to:
  2. #22
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Quote Originally Posted by eagleslayor View Post
    I don't know if we are worrying too much, I mean data loss is a problem, and we rather not take risks, and now I'm getting worried about motherboards...
    Yes you are worrying too much. My set up has been in use more about 10 years now. Not one data issue.... ever, and I was the one earlier that bent the frame on two trucks. Not just a little on one of them. They where full ladder frames and partially boxed, PCs are more durable than you are.
    TruckinMP3
    Read the FAQ!
  3. #23
    Low Bitrate unixxx's Avatar
    Sep 2005
    CA, USA
    I crashed my one year-old horizontally mounted 2.5" drive by fishtailing the right front and rear right wheels into a tree while climbing a muddy hill off-road. The right front inner tie-rod bent and then snapped and both wheels were gouged and became unbalanced. Drives really don't like being off-road.... I think I'm going to go with compact flash this third time....
    # cd /home/fuzzymuzzle.com
    Intel Pentium M Dothan 750 1.8GHz 533MHz 2MB
    iBase MB896F w/ Intel 915GM
    [■■■■■■■■■■■■■■■■■■■■] 50% Done
    (Writing Front/Back End, Designing Electronics, and Completing Install)
  4. #24
    Oct 2003
    Vancouver, BC
    I've only ever had one failure and that's because my car had a leaky top. It didn't completly stop spinning and still worked to some degree but for some reason, the bios recognized it as an old Altair HD. Replaced the drive and I was good to go, two accidents later (one that wrote off the car) and the new drive was still going. It's out of commission now cuz it's too small. The new car had a 120 gig that was replaced because I ran out of space, running a 320 gig in there now. Both cars were MR2 Turbos, the current one is riding on race springs instead of sports springs. There is nearly no give in the suspension and is one of the most bumpiest rides I've owned. In both cars the drive was mounted vertically with the cable end facing the back of the car. I also built a carputer for a friend of mine who just bolted it flat in the trunk and it died in a year's time.
  5. #25
    Low Bitrate Ali_2k's Avatar
    Oct 2005
    simple solution is dont store anything u wouldent store on a say a portable flash pen... like coursework or an important file for work, this way if the worst does happen and ure HDD does break, send it back to the retailer... every product has a minimum one year warrenty, wich is easy to get replaced if you speak to them on the phone... emails are a hideous invention when it comes to customer service.
    but yeh, basic rule is backup anything important, or dont put anything important on the drive in the first place
    -2k
  6. #26
    Nov 2007
    Montreal, Quebec
    Quote Originally Posted by RocketSled View Post
    I make hard drives for a living. Have been in this business for 20 years. Here is some info you can take as fact.......................
    Thanks for the info RocketSled, great read
  1. Hard drive upgrade problems :-(
    By Arex in forum General Hardware Discussion
    Last Post: 04-29-2006, 12:53 PM
  2. hard drive help
    By Cypher333 in forum General Hardware Discussion
    Last Post: 08-01-2005, 08:12 AM
  3. Did you know "single" Hard Drive Booted Faster?
    By grandamp3 in forum General Hardware Discussion
    Last Post: 09-03-2004, 12:50 PM
  4. carputer hard drive died in 3 days
    By therussman2002 in forum General Hardware Discussion
    Last Post: 08-10-2004, 01:49 PM
  5. Damnit my hard drive crashed again :(
    By Squeezer in forum General Hardware Discussion
    Last Post: 02-15-2003, 04:50 PM
