hrmm make sure you have the proper line selected in the RRConfig?
Hey Pyros,
Maybe you can help me. I've got XM working great in RR. But every time I boot up (every time I start my car) - I have to go to the system volume control panel and:
choose recording properties,
unselect 'line-in',
then reselect 'line-in' to hear XM.
Do you know why it might be doing this? Or what I could do to be able to just boot and hear XM?
Thanks a ton.
check pm
I have noticed the mouse DIN connector I used fits loosely... What is the adapter mentioned above, and where do I get this?
Also to note...
I am wondering why there are 2 +12v inputs to the XMD1000. After making the mistake of assuming both were connected on the radios circuit board, I took the circuit board out and they are connected to a missing connector labeled "Signal". My mouse connector I used was missing one of the pins (forgot if it was 6 or 7), so I soldered the 2 +12v circuits together at the "Signal" connector. After that I was up and running.
I am thinking one is on constant, and the other would be on at ignition on/ Power on.
If anyone knows the nitty gritty on the 2 +12 volt circuits, please enlighten.![]()
Does anyone know the maximum power that an XMD1000 can receive? I mean, if I use an antenna different from the ones for car?
I need to use a cable of 7 ft and I´m intending to use an antenna which has about 25dB of gain.
Could someone help me? What type of cable shall I use? I´m intending to have that on my Clarion MAX675VDII and I need an XMD1000 receiver and also an XMDCLA100 Smart Digital Adapter.
Thanks for all.
i just made a cable for my project and it worked lie a champ
note set com port to hardware control and turned down the recive buffer to help debug
check out ihacked site or pm me and i will get you the schem.
