Results 11 to 20 of 29
Thread: FAQ: How to install a DVD R/RW in your Xenarc 700IDT
  1. #11
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    too bad you dont have a slot load. Awesome job!
    PC Components:
    My work log
  2. #12
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Thread moved to FAQ section and added to FAQ to the FAQ's. Awesome job! Thanks for documenting it.
    Want to:
  3. #13
    Dec 2004
    thats pretty. musta took some nerve to hack up a $500 piece of equipment. lol
  4. #14
    Low Bitrate cdcamaro9534's Avatar
    Nov 2005
    In the hills of Kentucky
    Quote Originally Posted by Peoples
    Actually I was debating about doing a slot load. But cutting that front plastic panel is hard enough and to get a clean look, and would be very difficult, but not impossible. I like this look just for the fact the plastic on the DVD drive door matches great, and looks like it came from the factory that way. But I think Xenarc was thinking about doing something like this, because the way 700IDT is built, it looks like they designed it for a DVD drive down the road.
    But thanks everyone for the compliments And if anyone has question while there doing this, just pm me, I'll be around, and I'll try to help as much as I can.
    1995 Chevy Camaro
    2003 Dodge Ram 1500
    VIA EPIA M10000 Mini-ITX Motherboard
    Iguidance GPS
    Road Runner Frontend w/ DFX5.0.3
    Xenarc 700IDT with DVD CDR/RW
  5. #15
    Sep 2005
    That's very good work, better only with a slot-in drive...
  6. #16
    Constant Bitrate rotarypower101's Avatar
    Oct 2004
    Portland/MtHood Oregon
    Another member found this. Seems like a real nice cheap solution for you guys that have the IDT, and want a usb 2.0 compatible solution.
    And from the looks of it, it should not have any issue interfering with the spring mechanism, just by looking at it.
    Should be a nice solution, considering sources that sell these just hiked up the price from around 45-50 to 70+ for the same item not too long ago.
    http://cgi.ebay.com/ws/eBayISAPI.dll..._BIN_Stores_IT
  7. #17
    Oct 2004
    ^hope thats useful to someone
  8. #18
    Apr 2006
    I know this is a somewhat old thread but I just followed it and wanted to show how mine turned out and thank the OP for this as it was a big help.. Only differences with mine is I used a slot load DVD-RAM drive, I didnt grind down those posts and I didnt remove the DC plug I drilled a new hole for my cables.. I am pretty impressed with the way mine turned out.. was a little scared at first to do this to a brand new LCD but said screw it..
  9. #19
    Nov 2005
    Looks good. I put the one I did for this post in my Camaro. I just bought a new Dodge Ram last week, so I plan on doing the same, except I'm going to do the slot one also.
    1995 Chevy Camaro
    2003 Dodge Ram 1500
    Iguidance GPS
  10. #20
    Apr 2006
    In case you're curious I used Panasonic UJ-85J for the DVD drive and that Slim to USB shown above and had absolutly no clearance problems leaving the 4 posts in tact.. In fact it helped keep the drive level in my opinion. I put 4 strips of the foam double sided tape in between the posts, and I took a decently thick rubber washer, cut it in half and took some good glue and glued the halves down right behind the drive to help hold it in place.. I was concerned the tape might not hold completely.
  1. FS: Xenarc 700IDT - US/CA/Santa Barbara
    By bdrezner in forum Classified Archive
    Last Post: 03-04-2006, 01:05 AM
  2. Xenarc 700IDT?
    By rdcravens in forum LCD/Display
    Last Post: 04-10-2005, 12:53 PM
  3. Xenarc Installed but flickering
    By Pabs in forum General Hardware Discussion
    Last Post: 02-16-2005, 09:40 AM
  4. WTB: Opus 90W psu, dvd, 7" xenarc
    By pottillo in forum Classified Archive
    Last Post: 02-03-2004, 11:57 AM
  5. Pioneer DVD Navigation Installed
    By PoBoy in forum Off Topic
    Last Post: 07-15-2002, 04:54 PM
