@eco:
I was curious about that offroad menu, but:
When looking into engineering menu with a C-Class/CLK/B-Klass NTG2 Comand there is no menu item "Variant" in Diagnosis menu found.
Also - Why should the system loose the setting, if anything could be set in that menu part ?
Why does the ML and R-Class Comand (which is also an identical NTG2) does have the "compass" softkey upper left ex works, when pressing the nav button?
The Dr.DIST Menu can only be found in E-Class ENG Menus
Actually, having a 2006 Firmware in x211 and a 6.1 DVD in NTG2 based Comands, the softkeys to reach the ENG menu are completely removed.
Problably on can test if manipulation is possible via star diagnosis??
Thx
LinkBack URL
About LinkBacks
