View Poll Results: What is the best GPS Receiver?
Voters
278. You may not vote on this poll
  • BU-303
    23 8.27%
  • BU-353/355
    139 50.00%
  • Holux GR-213
    37 13.31%
  • Holux GR-212
    8 2.88%
  • Royaltek Sapphire
    1 0.36%
  • Garmin unit (post your model!)
    18 6.47%
  • Ublox unit (post your setup!)
    2 0.72%
  • Bluetooth unit (post your model!)
    9 3.24%
  • OEM unit (post your setup!)
    12 4.32%
  • Other (post your setup!)
    37 13.31%
Multiple Choice Poll.
Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 52
Thread: FAQ POLL: What is the best GPS Receiver?
  1. #21
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by Quattro
    how did you forget to put the Rikaline 6010 in your poll????
    btw, that's what I use.
    Quote Originally Posted by 0l33l
    Ummmm... were the hell is Earthmate
    I voted other.
    because there's a 10 item limit.
    Quote Originally Posted by DarquePervert
    If there are other GPS units you feel should be added to the list, I can't. The poll is limited to ten entries. However, please choose OTHER and post your setup so newbies can see what options are available!
    Jan Bennett
  2. #22
    Raw Wave tj!2k4's Avatar
    Oct 2004
    From my experience, it is not waterproof.. water-resistant perhaps, but after opening it up to repair a cut cable and seeing the components rusting away, definitely not waterPROOF.
    My experience with this Earthmate has been good.. If you put it in a location where it has a decent view of the sky and can get a decent lock. Mine was mounted on the inside of my fiberglass trunk lid. Lack of magnet mount and the detachable USB cable limit your mounting options the vehicle's interior.
    Quote Originally Posted by uriel
    I have the BU-353 and it's great!!
    BU35x/SirfSTAR III.. definitely the best way to go at this point.. great chipset. Mine works inside the passenger compartment where the Earthmate failed.
  3. #23
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Well... then maybe the BUs and the Holux should been combined.
  4. #24
    _
    Mar 2004
    Little Elm, Texas
    if they were, someone would come in and complain about that...
    Jan Bennett
  5. #25
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by Red GTi VR6
    So true
  6. #26
    Raw Wave shotgunefx's Avatar
    Apr 2005
    Boston, MA
    Just got my Holux 213, works great. Plugged it in and got 11-12 satellites indoors almost immediately.
    Even more impressive is I live tucked between two big banks, I can barely get FM/AM or TV reception in here. Lot's of shielding, lot's of noise.
    The only issue I have is that at first, I had problems accessing it or if I did, I'd get read errors. It turns out that there must be something buggy with the PL2303 drivers for linux. I have another PL2303 serial converter on the machine too. It recognized both correctly, but it won't work with both plugged in.
    Strange.
  7. #27
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    bu353. mounted on my roof and never ever have any problems with it connecting or sat counts.
    Live mp3Car Facebook Chat
  8. #28
    Jun 2006
    Vote other!!
    Well, I looked at all the available USB GPS units like the ones on the list of choices, but I didn't want the cable coming out the side of it. Impossible to mount it externally and have it look good (with no wires going around). Well, I have a 1967 mustang that I am installing all this in and I want it to look stock from the outside and from the inside (mostly). I was wondering how I could minimize the impact and the eep the good looks. I finally, after months of searching (actually a couple hours on the internet), I have found what I need. I have been planning on removing my antenna from the outside of the car and hiding it on the inside of the windshield, so I was going to have to fill in the hole it is currently mounted in, and repaint the whole panel as this would be a big hole to fill. Then when I found this GPS unit, I knew that I could just use the old antenna hole. I have not tested it yet, but I do have one here. It's waterproof, It will be sealed against the body in the old antenna hole with silicone and locked in place with a locking ring with the nut and the silicone will adhere pretty well. And it comes with a 15' cable to go through the firewall, under the carpet and under the passenger's seat. This is the best option I have found and know that a lot of you will be taking my idea, thus the long post before I tell you which one. The US Global Sat MR-350 WAAS Enabled Water Proof GPS Receiver. I am including two pictures, one of the unit, pretty cool and one of the design specs.
    picture of it
    <img src="http://i31.photobucket.com/albums/c355/cheshireccat/MR-350_.jpg" border="0" alt="goto http://i31.photobucket.com/albums/c355/cheshireccat/MR-350_.jpg">
    and the specs:
    <img src="http://i31.photobucket.com/albums/c355/cheshireccat/MR350_specs.jpg" border="0" alt="Goto http://i31.photobucket.com/albums/c355/cheshireccat/MR350_specs.jpg">
    Now that you have seen it, what do you think? pretty good option, just drill a hole and you run the cable and done...
  9. #29
    Jul 2006
    Garmin 15L
    Garmin 15L: Small, cheap, works
    Hirschmann GPS, WiFi, GSM rooftop antenna: High geek factor
    See below, it's in the lower right of the top plate. This brick fits inside an ampie case.
  10. #30
    Apr 2005
    Queens, New York
    I use a Holux GPSlim 236, great reciever!
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
  1. Question on Garmin 16 GPS receiver
    By cproaudio in forum GPS
    Last Post: 05-23-2008, 02:32 AM
  2. Proper Installation of GPS Receiver
    By ummagawd in forum GPS
    Last Post: 04-22-2005, 12:07 PM
  3. GPS poll
    By maxxell in forum GPS
    Last Post: 03-25-2005, 01:33 AM
  4. How do I setup my GPS Application ?
    By guino in forum RR FAQ
    Last Post: 03-20-2005, 03:17 PM
  5. what to look for in a GPS receiver?
    By doublestack in forum GPS
    Last Post: 10-01-2004, 04:05 PM
