View Poll Results: What is the best GPS Receiver?
Voters
278. You may not vote on this poll
  • BU-303
    23 8.27%
  • BU-353/355
    139 50.00%
  • Holux GR-213
    37 13.31%
  • Holux GR-212
    8 2.88%
  • Royaltek Sapphire
    1 0.36%
  • Garmin unit (post your model!)
    18 6.47%
  • Ublox unit (post your setup!)
    2 0.72%
  • Bluetooth unit (post your model!)
    9 3.24%
  • OEM unit (post your setup!)
    12 4.32%
  • Other (post your setup!)
    37 13.31%
Multiple Choice Poll.
Page 5 of 6 FirstFirst 123456 LastLast
Results 41 to 50 of 52
Thread: FAQ POLL: What is the best GPS Receiver?
  1. #41
    Nov 2006
    North Hollywood, CA
    I have n iBlue 737 bluetooth GPS receiver. It is amazing. I was using the unit sold by Belkin before, but that unit had issues pairing with my bluetooth and it would sometimes require a system reboot to get it to work. This has been pretty flawless so far. Once it locks onto satellites, it sticks to it even under crappy conditions.
  2. #42
    Low Bitrate susuking's Avatar
    May 2005
    SoCal
    i have the delorme unit... but you don't have it under the vote... sad, its a really good unit, i've been using it for the past two years, and its now on my second setup .. still working great. and i just dump that thing into my glove compartment with my carputer under my seat. it have great reception even in my glovebox under the airbag module.
    Progress Bar: [//////////]100%
    Have M10000, 40gb 2.5"hdd, i guidance, wireless,slim slot drive, delorme gps, roadrunner, liliput touchscreen, opus150w ...
    all fabrication done...
  3. #43
    FLAC DodgeCummins's Avatar
    Oct 2000
    DFW area
    I have had the now discontinued Garmin GPS 35 since I started this journey...roughly 1998.
    All in one unit, weatherproof...but I have mine mounted inside. Quick locating, maintains signal except in the worst conditions (tunnel).
    Mandatory NEMA output via Serial cord...about 10' long...can take input voltage from 6 to 40 volts.
    A rock solid unit.
    Too bad you can only find them on ebay...if you are lucky.
    I guess they also have USB models now...
  4. #44
    Feb 2007
    Taylorsville, UT
    I bought a No name one off ebay that supposed has the MTK chipset which they are claiming to be better than SiRF III -- we shall see about that. It should arrive next week I will post up with some reults.
    -James
    Car: 2004 GTI VR6 24v Turbo 2.8L, GT35R, 630cc, Unitronic, Bosch 044, etc, etc..
    Main PC:i7 920@4Ghz, 6GB DDR3, MSI X-58 Pro-E, Win 7 x64 RTM, Scythe Mugen2, 128GB G.Skill Falcon, 2x ATI4850 512MB Crossfire, Auzentech X-Fi Forte, Grado Labs SR-80
  5. #45
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Mark I eyeball and a map. It always works and does not depend on Sat locks.
    TruckinMP3
    Read the FAQ!
  6. #46
    Constant Bitrate moboman's Avatar
    Sep 2007
    Cincy, OHIO
    I have 2 Garmin GPS USB 18.
    https://buy.garmin.com/shop/shop.do?cID=139&pID=6445
    I am very happy with the accuracy, and the maps are very good that come with the gps. I hate how the gps and the maps are locked so they only work together. Maybe if these companies would spend a little less worrying about pirates, they could make the product cheaper. For a little over a hundred bucks for the unit with maps, the price cannot be beat.
    My Worklog
    I'm using my carputer 100%, but I still need to make it easier to use.
  7. #47
    Nov 2007
    Unhappy A question
    what does BU-353/355 stand for ?
    thanks you
  8. #48
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    it is the model number of the GPS receiver
  9. #49
    Nov 2007
    Red face
    Quote Originally Posted by meddler View Post
    thank you ! i know that but what is its name ?
  10. #50
    Jun 2006
    tymt:
    It is the model number for the GlobalSat series of GPS recievers. You can check out more about the product by going here --http://www.globalsat.com.tw/eng/prod...l_00000044.htm
    My question for owners of the system: What map software are you using with the GlobalSat BU-353?
  1. Question on Garmin 16 GPS receiver
    By cproaudio in forum GPS
    Last Post: 05-23-2008, 02:32 AM
  2. Proper Installation of GPS Receiver
    By ummagawd in forum GPS
    Last Post: 04-22-2005, 12:07 PM
  3. GPS poll
    By maxxell in forum GPS
    Last Post: 03-25-2005, 01:33 AM
  4. How do I setup my GPS Application ?
    By guino in forum RR FAQ
    Last Post: 03-20-2005, 03:17 PM
  5. what to look for in a GPS receiver?
    By doublestack in forum GPS
    Last Post: 10-01-2004, 04:05 PM
