Page 1 of 4 1234 LastLast
Results 1 to 10 of 36
Thread: FAQ: Reasons for not installing anything underneath the seats.
    _
    Mar 2004
    Little Elm, Texas
    • There is no place to properly ground anything underneath the seat. Most people would try and use the seat bracket bolts. These are not good grounding points for a few reasons.
      - Usually these bolts are covered in grease, grit, or grime, thus making the ground a bad ground.
      - These same bolts are usually covered in paint, as is the threaded part that the bolt goes into.
      - Those mounting points usually have carpet underneath them, meaning that the ground is not solid.
    • That dirt, grit, and grime got there somehow. That same dirt, grit, and grime will get in whatever piece of electronic equipment you put underneath the seat.
    • Cokes, fries, onions, chili cheese dogs, cheetos, twizlers, etc. all end up under the seats. Do you really want that right next to your expensive electronic equipment?
    • If passengers can see it, they will mess with it. I know that we all like to think we can trust our friends. The fact of the matter is that people are curious. If they see a bunch of wires sticking out they will play with them. Not only will you risk having your passengers pulling things apart, you also risk them shocking themselves. Though you might think “Good, they deserve it then”, you can still be held liable. Sucks, but that’s the truth.
    • Even if you ask people to watch their feet, it’s like a magnet. Their feet will find their way under the seat. In doing, so they will break wires, break solders on boards, and introduce all kinds of foreign objects from their shoes that you don’t want around electronics.
    • The seat moves, you can try all you can think of, but it moves. There are things beneath the seat that will catch wires and pull them out. Moving pieces are never a good thing to mount next to or around unless you have the proper materials, and 9 times out of 10, you won't.
    • Do you really hate your equipment that much that you want to fart on it?! I'd sure hope not!
    This is a general standard that many of the car audio shops follow. These are the reasons for that.
    It's not a suggested practice.
    Jan Bennett
    Apr 2005
    Queens, New York
    Quote Originally Posted by Red GTi VR6
    This looks familiar!
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
    _
    Mar 2004
    Little Elm, Texas
    yeah - I've been seeing a lot of people want to do it that way and not understand why it's not a good idea, so I decided to post it up here.
    Jan Bennett
    _
    Mar 2004
    Little Elm, Texas
    added a few other things in there as well...
    Jan Bennett
    Variable Bitrate breaker021's Avatar
    Apr 2005
    Midtown Manhattan
    gti - very nice list of reasons!
    - sh00k
    Duct tape and a Bandana for the win, b!shes!!!
    My Setup:http://www.mp3car.com/vbulletin/show-off-your-project/73500-06-scion-xb-tablet-in-the-box.html
    Cost so far: Less than a grand ;]
    _________________
    Economy/Commuter cars + Computers = many entertained miles
    _
    Mar 2004
    Little Elm, Texas
    hehe - it happens, same here at my job, people just get ahead of themselves....no biggie! - deleted that post of mine since piabu PMd me and told me he deleted his to help keep this thread clean.
    Jan Bennett
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Add another one: people will intentionally kick it to see if it restarts
    Raw Wave lostreception's Avatar
    NY
    i happen to agre with many of the reasons but i have my case bolted to the top of the seat and there is a bumper on the back of the case i know that the bumper doesnt protect from everything but it does protects from cheetos coke dirt etc
    and a good fart every now and then cleans the heatsink its a good thing
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    [(o)______(o)]b VanPimpin'
    LostReceptions Apps D/L Here
    GPSGasoline- Rewriting
    CarPCNetwork
    Oct 2004
    NY
    hey, I have a ton of equiptment on sliding drawers under my 2 rear seats!!! I even built new seat mounts to accomidate these... the brain of my iva-d300 is under there, with the brain of my h700... the d300 expansion module, a 4 into one unilink box & the video box for my 15.4" overhead dropdown!!!!
    I ALSO have a bunch of equiptment under the front passenger seat including a netgear dual hardrive network enclosure and a kyocera kr1 wireless router!, I'm adding another motherboard under there soon probably as well...
    If I couldn't put equiptment under my seats I'd have no room for passengers
    ah... maybe I should mention that my car is a minivan & the seats are a bit higher than an average car... PLUS I have stripped my interior to the bare & everything is prepped to accept this setup properly.... I even built a center wire tunnel that runns the center of the truck for the many wire harnesses that I have going on..... I can run a wire at any time from the front center console to the rear of the truck with a snake through a tunnel
    the end story is, although everything you guys/gal has said has merit, there can be exceptions to the rules
    red has pointed out how grounding points can be problematic under seats, & while this can be true, & a seat bolt can usually be less than ideal, this doesn't mean you can't run a ground TO under the seat along with whatever power your running...., & have it come from a good grounding point..
    I'd also say that the biggest problem I see with under seat installs is that there not done right most of the time.... but if done correctly they can provide valuable space
    you have to realize how much the center of the seat can come down when ocupied(a lot!), & you have to make sure you have more than adiquate clearance for FULL sliding back & forth, & up & down if applicable.... I have had situations that I have utilized this space & have had to limit the travel of the seat mechanically to accomidate it.... NEVER just trust that no one will move it!!!
    most of the time to do this properly will involve removing the seat, & possibally building a mounting board, or pedistal brackets..... under the seat is NOT where you just want to slide something under there..... laying on the carpet.... that's what gives underseats a bad rep, is because most of the times it's done sloppily & you have to also account for bad weather conditions..... you'd be surprised how trashed the underseats can get in snow & stuff... if you use a bit of forthought the seats can be a good place for equiptment, if done properly...
    also keep in mind that equiptment that requires good airflow can be problematic, amps can be problematic.... under seats is usually not an ideal space for equiptment, but not ruled out either......
    Jul 2006
    And...
    Another point to consider (as pointed out by my mechanic brother) is that newer cars actually use the underseat space for electronics such as the weight and airbag sensors in my 2005 Hyundai. This is becoming more and more common apparently. You don't even want to mess that kind of stuff up.
  1. FAQ: Installing XM Radio on Your Carputer, a Tutorial
    By Bugbyte in forum The FAQ Emporium
    Last Post: 03-14-2008, 01:36 AM
  2. Installing Monitors in seats without headrests
    By chadb in forum LCD/Display
    Last Post: 12-30-2005, 10:10 AM
  3. FAQ question about Skin installing
    By QuickCarl in forum ME Archive
    Last Post: 11-02-2003, 12:46 PM
