Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 58
Thread: FAQ: How do I power my DC-DC PSU on my workbench?
  1. #21
    Banned
    Jun 2006
    Hmm, I'll check that setting. I thought that the PSU was the one that controlled the on/off via the ignition cable?
  2. #22
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by salvi View Post
    Yes. It controls on and off from the ignition line status. This option is in the BIOS for computers in a house/business. If the power goes out, and then comes back on, do you want the computer to come on, stay off, or return to the last known state.
    In the car, if you didnt have a smart DC-DC, and had it set to ON after power failure, and the power relay tripped by the accessory wire, it will start but from a cold boot every time, and it would pull the plug when the engine dies. Not shut down the PC, but yank out the cord.
    So every time the key goes from off to on, the computer must cold boot because there is not power for Standby, and both hibernate and standby would require you to press a button to bring it out of that state. The BIOS settings only work for when it is a cold boot.
    1.9in x 2.9in -- 47mm x 73mm
  3. #23
    Banned
    Jun 2006
    I was just confused since I'm using the M1 on the workbench. With my SP13000 this must not have been enabled. I'll disable this setting and hopefully it works like a charm.
  4. #24
    Banned
    Jun 2006
    I just checked all the settings and there is no such setting. It's a VIA MII motherboard, anyone know where I can find such a setting?
  5. #25
    Mar 2006
    Via uses the Pheonix Award BIOS, so it looks like this:
    You see the "Power Managment Setup"? Try there...
  6. #26
    Banned
    Jun 2006
    I was in the PowerManagement setup but didn't find the option.
  7. #27
    Mar 2006
    "Restore on AC Power Loss". Change that. It really isnt that hard. Unless you bought a really old board, your BIOS should look like that. I have had the M10k which is older than the MII and mine had this option. This is a basic option that has been around forever. The only BIOS's I know of that dont have this option are either really really old (and then it was usually a user settable jumper on the mobo itself), or laptops (they have batteries, so they dont care).
  8. #28
    Newbie Z_Rukia_Z's Avatar
    Aug 2007
    MA
    Thanks Darque and Vlad...I got my workbench up and running because of you two!
  9. #29
    Apr 2006
    Sydney, Australia
    Nice and simple - great tip thanks!- will use this method as opposed to a spare car battery for bench testing.
    PEACE
    Kosti
    New Car PC Build list in progress
  10. #30
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    Hmmm............
    I just either use a 12v battery or plug my atx power supply into the standard connectors on the MB.
    Simple and works fine for me!
    Leonardo Da Vinci
  1. FAQ: How to Wire an OPUS PSU
    By Quattro in forum The FAQ Emporium
    Last Post: 08-26-2006, 01:38 PM
  2. Replies: 5
    Last Post: 07-22-2005, 01:59 AM
  3. Power USB hub from psu
    By meyer64 in forum Power Supplies
    Last Post: 03-20-2005, 11:34 PM
  4. Need help finding an AC to DC power adaptor
    By Squeezer in forum General Hardware Discussion
    Last Post: 12-29-2000, 01:27 PM
  5. dc to dc ATX power supply
    By Kaizer Soze in forum General Hardware Discussion
    Last Post: 10-21-1999, 08:47 PM
