I used a momentary switch from a PC. The switch has three pins. One is four voltage in, one for voltage out and one for ground, I'm pretty sure. Since this is in-line with the power, you don't need a ground wired up. You're just using this as a simple switch to close the connection on a +12v line.
LinkBack URL
About LinkBacks
i am installing
