Page 3 of 7 FirstFirst 1234567 LastLast
Results 21 to 30 of 66
Thread: FAQ:Resuming from Hibernation; A beginners guide to Devcon
  1. #21
    Newbie braidy's Avatar
    Feb 2006
    Quote Originally Posted by v8 scimitar View Post
    How are you running Devcon in a cold boot? You shouldn't ever have to use Devcon on a normal boot and that's not what it is designed for. If devices don't load properly on a cold boot then you have something very wrong on your install.
    On cold boot, nothing about Bluetooth shows up in device manage until I push the BT button on the front of the laptop. Then all the BT device entries show up. This is why I need to enable BT on startup. How do I do this?
    Also, I fixed the wireless.
    1994 ED Ford Falcon GLi Classic
    Hardware: Acer Travelmate 3200, Car Charger, Lilliput 7"
    Software: Roadrunner (Simplistique), WinXP Pro, ShutControl
    Progress: [|||||||| ] (100% - For Now)
  2. #22
    Maximum Bitrate S4Per's Avatar
    Jan 2004
    Seattle, WA
    Quote Originally Posted by braidy View Post
    i'd be there's some bios / software setting on your laptop that gives the option to auto start bt?
  3. #23
    Feb 2006
    Quote Originally Posted by S4Per View Post
    No BIOS option, no software option to my knowledge.
  4. #24
    Oct 2005
    Does someone have the unsecured version of this pdf? Or can they post the script entries for auto-it. I am not sure about the spacing, and can't copy out of the pdf.
    Thanks.
  5. #25
    Maximum Bitrate v8 scimitar's Avatar
    Jan 2005
    Scotland
    The spacing works the same as any other DOS command as in program space switch space and so on. For example devcom space /hwids space *usb* . Its locked to stop people blindly copying the commands as 95% of them wont work on their machine. The text select still works so its easy enough to place a cursor on and move through the commands.
    Visit my site V8 Scimitar
    SP13000, 300GB SATA HD, 1GB DDR. Opus 150, K301 screen, Cisco WIFI, AQmax GPS, RoadRunner and FreeDrive, Sony MEX-R5 head unit. 4 years installed and it just keeps running!
  6. #26
    Sep 2007
    West Springfield, MA
    I have problems with my external DVD drive and WiFi stick when coming back from hibernation. Will Devcon make it so I don't have to restart to get everything working again?
  7. #27
    Jan 2005
    Scotland
    don't know why don't you try it and see
  8. #28
    Newbie tipito's Avatar
    May 2008
    Buenos Aires - Argentina
    hi, the link to "hibernate trigger" is broken, can some help me? i have use google and nothink, every link goes to the same download place.
    Thank
    PS: sorry my English, i know is not god.
  9. #29
    May 2004
    I tried this on my BU-353 GPS receiver, but haven't had much luck.
    I am pretty sure I chose the correct ID.
    Maybe my situation is unique.
    Currently I am using Xport to split the GPS port to com 2 and com 3. Iguidance uses com2 and Centrafuse use come 3.
    When I execute the disable command in dos it says device disabled successfully. But while doing this I am monitering the device manager and notice the gps is not disabling.
    Do I need to somehow disable xport also? and then disable the gps receiver?
    Has any successfully used this with centrafuse and iguidance?
  10. #30
    Jan 2008
    After a bit of searching I have managed to find a place where I could get hibernate trigger finally. Almost all the links you will find including the one in the pdf link to the site that has been removed.
    Luckily for us all theFluxmedia Forums and specifically coffeejolt has uploaded it. If you dont have centrafuse I guess just dump the other scripts and keep the hibernate program.
    Hope the guys at fluxmedia dont mind. If they do we really need someone else to host this.
  1. Audigy 2 NX and hibernation
    By backspace in forum Car Audio
    Last Post: 04-28-2006, 02:56 PM
  2. 5 minutes to complete hibernation? WTF?
    By DRWeside in forum General Hardware Discussion
    Last Post: 03-12-2006, 11:36 PM
  3. Question regarding Devcon & GPS hibernation
    By Sonicxtacy02 in forum GPS
    Last Post: 08-15-2005, 01:12 PM
  4. Again DevCon with another problem
    By Konrad in forum General Hardware Discussion
    Last Post: 02-04-2005, 07:59 PM
  5. Odd Off Topic-ness on Hibernation
    By Vchat20 in forum General MP3Car Discussion
    Last Post: 01-31-2005, 06:41 PM
