Page 4 of 7 FirstFirst 1234567 LastLast
Results 31 to 40 of 66
Thread: FAQ:Resuming from Hibernation; A beginners guide to Devcon
  1. #31
    Maximum Bitrate v8 scimitar's Avatar
    Jan 2005
    Scotland
    you must be disabling the wrong object if its still active.
    http://www.softpedia.com/get/System/...-Trigger.shtml for hibernate trigger.
    Visit my site V8 Scimitar
    SP13000, 300GB SATA HD, 1GB DDR. Opus 150, K301 screen, Cisco WIFI, AQmax GPS, RoadRunner and FreeDrive, Sony MEX-R5 head unit. 4 years installed and it just keeps running!
  2. #32
    Jan 2008
    Actually that link doesnt work either it just links back to the same one in the pdf. I did manage to find this though, it's the new site.
    Hibernate trigger
  3. #33
    Jan 2005
    Scotland
    Sorry I didn't follow the link. I have updated the PDF.
  4. #34
    May 2004
    Anyone else using devcon with Xport?
  5. #35
    Maximum Bitrate wizz's Avatar
    Nov 2004
    Leicestershire UK
    V8 Scimitar Can you help me with my problem........
    I've been trying to use devcon/autoit/hibernation trigger to stop a 3 usb mobile broadband modem to allow me to hibernate, but have just found out that it is the modem coms software that is stoping hibernation and not the device itself. If I exit the software, my system will go into and out off hibernation correctly.
    I therefore need to stop this program prior to hibernation.
    The program at present auto-starts with windows boot via the startup folder. Unfortunately, I have to then click a connect box in the software for the modem to go online.
    To shutdown the software I have to click a disconnect box and also confirm a "yes/no" box to disconnect the modem.....then finally stop the program itself.
    Is there a way to, at least, disconnect and shut down the program prior to hibernation so that when I switch off my ignition the M2-ATX can initiate the hibernation.
    PS: I see your from Scotland......I'm over on digital-car.co.uk as well as mp3car.com, with the same name/avatar..........got a Focus too !
    Car : Ford Focus Zetec 1.6
    Carpc :Lin-ITX Plus 7" touchscreen/Toad 8" roof screen
    Morex 3688 case/M2-ATX PSU/Commell V-672 P4 3.2Ghz/1024DDR2/40GB 2.5" SATA HDD/Sony DVD/CDRW
    BU303 GPS/Mercury 11b WiFi/Parking Sensors
    Colour I/R Reversing Camera
  6. #36
    Jan 2005
    Scotland
    Hi Wizz
    Yes I have seen you around on the other side. I have the same username over there too.
    The only way I can think of right now is to use some scripts to kill the app and start it again. You better test if this is ok because it is a bit of a brutal way to shut down a program and it might not like it.
    For command prompt (DOS) create a bat file with taskkill /im NameOfProgramToEnd.exe
    Create another one with NameOfProgramToStart.exe this will only work in xp pro xp home doesnt have taskkill.
    Put these in hibernate trigger and your done. You could also create an exe to do this in AutoIT if you wanted as per my tutorial just change the commands. This will hide the dos window.
    You could also use Powershell http://www.microsoft.com/windowsserv...l/default.mspx .
    Create a commandlet with kill -name NameOfProgram and another with NameOfProgram again put these in hibernate trigger.
    There is probably a way to do it in VB script as well and you might find a nicer way to close the program instead of killing it but I don’t know what the scripts would be.
    There will also be a way to do it nicely via AutoIt but I would need to experiment. Unfortunately I am two days away from being out the country so I don’t have time at mo.
    I should also say you might have to put the path to the app depending how it is registered to get it to start (not to kill it though).
    Hope this helps.
  7. #37
    Nov 2004
    Leicestershire UK
    Quote Originally Posted by v8 scimitar View Post
    OK, Thanks for the info...I'll try it.
    That start bat wont take care of the connect button push......will it ??
  8. #38
    Jan 2005
    Scotland
    no it will just start the app. To do the connect part you would have to either be able to send a switch to the software or if you used AutoIt you can send messages or keystrokes if it will accept them. Dont know about the 3 software but the Vodafone software has a setting to auto connect anyway. Comming to think of it the Voda one if you pull the dongle the software shuts down and when you put it in it auto starts. Trouble is it takes ages to shut down so windows will hang when trying to hibernate. Hmm I will have a play at work tomorow if I get a chance and see if I can spot anything usefull to you.
  9. #39
    Nov 2004
    Leicestershire UK
    I tried an autoit script to shutdown the 3 software, but I get an alert box telling me to disconnect before trying to shutdown.
    After disconnecting and then trying to shutdown I still get another yes/no alert box to confirm shutdown
    I've looked through the program options....there is also nothing to allow auto-connect or anything similar
  10. #40
    Jan 2005
    Scotland
    Never got a chance to have a look today but it looks like the software is different to vodafone anyway. Look and see if there is a keyboard shortcut to accept the alert box. It might even be as simple as yes is default and you just have to send return. Maybe some of the coders can do a better app for you. The hardware is pretty much all the same so it could be you just need to talk to a common dll.
  1. Audigy 2 NX and hibernation
    By backspace in forum Car Audio
    Last Post: 04-28-2006, 02:56 PM
  2. 5 minutes to complete hibernation? WTF?
    By DRWeside in forum General Hardware Discussion
    Last Post: 03-12-2006, 11:36 PM
  3. Question regarding Devcon & GPS hibernation
    By Sonicxtacy02 in forum GPS
    Last Post: 08-15-2005, 01:12 PM
  4. Again DevCon with another problem
    By Konrad in forum General Hardware Discussion
    Last Post: 02-04-2005, 07:59 PM
  5. Odd Off Topic-ness on Hibernation
    By Vchat20 in forum General MP3Car Discussion
    Last Post: 01-31-2005, 06:41 PM
