+ Reply to Thread
Page 1 of 7 1234567 LastLast
Results 1 to 10 of 66
Thread: FAQ:Resuming from Hibernation; A beginners guide to Devcon
    Maximum Bitrate v8 scimitar's Avatar
    Jan 2005
    Scotland
    Windows not resuming from hibernation properly? Well this might be an answer for you. There is a utility from Micro$oft called Devcon that can disable and enable devises for you that should help sort the mess. Trouble is it isn't very user friendly and seeing lots of people struggling with it over on another thread I decided to do this tutorial. So grab your copy here and see if it helps you out. It is written for the complete beginner so goes through the absolute basics.
    It isn't a guaranteed fix but if windows wont come out of hibernation or some USB devices don't work properly when it does then this is well worth a go.
    Usual applies have a read through it first before you start messing about and if you still don't understand it then leave it alone as I am not going to be responsible if you break your machine, although it's unlikely.
    Any questions, ask away and I will see if I can help you out.
    Visit my site V8 Scimitar
    SP13000, 300GB SATA HD, 1GB DDR. Opus 150, K301 screen, Cisco WIFI, AQmax GPS, RoadRunner and FreeDrive, Sony MEX-R5 head unit. 4 years installed and it just keeps running!
    Variable Bitrate rcdash's Avatar
    Dec 2004
    Very nicely done. Thank you.
    Oct 2006
    St. Louis, MO
    Thanks for the write up! This has fixed my GPS locking issues.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Thanks for this. Edited title to include terms "resume from hibernation"
    Want to:
    Jan 2005
    Scotland
    Glad it helped you out jonDubya.
    No problem Bugbyte good thinking.
    Oct 2006
    Will these fixes work when running windows on a Mac Mini running boot camp? I understand that there are a lot of problems with waking up windows after its been to sleep. Thanks for your help.
    Jul 2006
    worked like a charm, thanks! i just disabled and enabled my entire usb hub, so everything connected to it started working fine.
    Jul 2006
    here's a neat question:
    two of my devices (TS and BT) have the same ID: PID_0001. When I use the disable command it disables both. What can I do?
    EDIT: nvm, i got it. just use any other part of the hwid name, but NOT including any '&'s. For me, I had to use everything before the PID
    FLAC coucouillu's Avatar
    Nov 2004
    FRANCE
    Problem with Bluetooth USB stick
    Hi,
    I have tried your solution but it doesn't seem to work.
    After resume, the blue light of the stick is off ; I run the code with the right PID for my Bluetooth USB stick but I get a response that tell me that the device doesn't exist. Like it wasn't pluged.
    I am obliged to unplug and plug the stick back to make it work.
    Any ideas
    Brice
    Constant Bitrate aperali's Avatar
    Aug 2007
    Rio de Janeiro, Brazil
    this procedure can be done for non usb devices? like a ide dvd drive?
+ Reply to Thread
  1. Audigy 2 NX and hibernation
    By backspace in forum Car Audio
    Last Post: 04-28-2006, 02:56 PM
  2. 5 minutes to complete hibernation? WTF?
    By DRWeside in forum General Hardware Discussion
    Last Post: 03-12-2006, 11:36 PM
  3. Question regarding Devcon & GPS hibernation
    By Sonicxtacy02 in forum GPS
    Last Post: 08-15-2005, 01:12 PM
  4. Again DevCon with another problem
    By Konrad in forum General Hardware Discussion
    Last Post: 02-04-2005, 07:59 PM
  5. Odd Off Topic-ness on Hibernation
    By Vchat20 in forum General MP3Car Discussion
    Last Post: 01-31-2005, 06:41 PM
