Software
Media Players That Support Kernel Streaming
Foobar2000
Foobar2000 supports kernel streaming natively. To activate it do the following:
Foobar 2000 -> Preferences -> Ouput -> change Output Method to Kernel Streaming.
Then you will need to change the
sound device to the sound card you are using.
If you are experiencing audio dropouts, you may want to change the buffer length. The default is 2048ms.
WinAmp
WinAmp will support kernel streaming with the addition of a kernel streaming plug-in.
Kernel Streaming Plug-ins for WinAmp
- WinAmp 2: You can find a Kernel Streaming plug in for WinAmp 2 available here from Steve Monks - http://www.stevemonks.com/ksplugin/
For some discussion or possibly for some support on this plug-in, check this thread -
Hydrogen Audio Forum - WinAmp: For a Kernel Streaming plug in for WinAmp, as well as FLAC and VolumeLogic - Torrent File
A note about this plug-in for WinAmp: Sometimes the play list will not advance automatically when a song finishes. You will have to manually press Next or select another song. This can be resolved by combining the Kernel Streaming plug-in with the VolumeLogic plug-in also included in this torrent. In Winamp’s output plug-in list, double click on VolumeLogic (setting it as the output plug-in for Winamp to use) and a window will pop up asking you to select the out put plug-in. Select Kernel Streaming from here. This will fix the play list advance issue so everything works. When you double click a song, however, rarely, it will not start. Just press pause twice and it will start like normal.
Media Players That Support ASIO
J. River Media Center
J. River Media Center Media Center natively supports ASIO.
Tools -> Options -> Playback -> change Output Mode to ASIO
Then you will need to change the sound device to the sound card you are using. Or, if you are using a ASIO -> KS wrapper, choose it.
Foobar2000
Foobar2000 does not support ASIO natively.
WinAmp
Winamp does not support ASIO natively.
WinAmp ASIO Plug-ins
These plug-ins can be found here:
http://otachan.com (For a translated version of the page, see here:
Translated Page)
Options -> Preferences -> Output -> change the output plug-in to the ASIO Output Plug-in -> Configure
Thread Priority - for audio only, Time Critical should be fine.
Turn resampling off, if it is on, you will no longer be playing bit-perfect.
