Mini-itx Motherboard Guides:
Page 7: http://www.geekdoom.com/Other/PDF/Na...0positions.pdf
I think there should be some sort of sticky in the FAQ or maybe Fabrication forum with links to a bunch of PDF's or something that detail all the specifications and mounting holes of things such as:
3.5" Hard Drive
2.5" Hard Drive
itx/uATX/ATX Motherboards
M1/M2/Opus/DSATX PSU's
Case fans maybe
Just all sorts of stuff regarding building your own custom case. I found that I spent the longest time googling for 3-view drawing with detailed information about where the screw holes were located, maximum length/width/height, and that sort of thing.
Might be useful to others.
1.9in x 2.9in -- 47mm x 73mm
MicroATX/uATX Motherboard Guides:
Page 10 & 12: http://www.formfactors.org/developer...matxspe1.2.pdf
Page 8 & 9: http://www.formfactors.org/developer...ATXaddn1_0.pdf
Section 2.1 Page 5: http://download.intel.com/design/int...mbatx_spec.pdf
FlexATX Motherboard Resources:
Page 9: http://www.formfactors.org/developer...ATXaddn1_0.pdf
That's very nice of you 2k1Toaster; why don't you start the FAQ thread yourself, though?
For Sale: Carputer (CarPC) & RCA Y-Adapter
Newsflash: Take a look at my unsold stuff above, thanks!
Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
How about some 3d cad files. That would help me out when using PRO/E. So far ive had to manually build these 3D parts.
Um, I guess this is where you put something witty.WITTY
My Web site, in the design stage. http://home.comcast.net/~cstrachn
Modified RRSkinEditor http://www.mp3car.com/vbulletin/rr-skins/65723-rrskineditor-bugs-fixes-comments-current-progress-outdated.html
Well I wanted some input first, and also If everybody contributes what they have, then we can put together a comprehensive FAQ all at once.
That would be cool too. Go ahead and upload them. I will use all of the info posted here in the final FAQ.
Post away!
As fas PDF's go. It would be kewl to create a PDF file with everything you needed to know as far as measurements. Like a full on Document. Although living Threads are kewl for added knowledge. Too bad that doesn't always happen.
edit: I will have to see what 3D Cad files i have or can create for people. Does anyone have preference on 3D file type?
Modified RRSkinEditor http://www.mp3car.com/vbulletin/showthread.php?t=65723
M1-ATX & M2-ATX DC-DC Powersupply
Page1 : http://resources.mini-box.com/online...dimensions.pdf
