Results 1 to 7 of 7
Thread: Software Review: NavigatoR2 From Cartft.com & Navigon
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    What it is/does: EU GPS Software With TMC
    Reviewed by: Terran Brown aka CCSnet
    Manufacturer : Navigon
    Model: NavigatoR 2
    Price: £183.11 GBP ( 13/04/07 )
    Rating: 8 out of 10
    Manufacturer website: http://www.navigon.com/
    Purchased at: http://www.cartft.com/catalog/il/767
    Pros: Great routing and voice direction
    Cons: The interface still needs working on for full CarPC use
    Tested with XP Bullet SR2, Navilock TMC GPS, Via 12000 MII with 512Mb Memory
    First off – I’m impressed, but then I have been using Destinator 3 for so long that’s easy. But still a few weeks on from starting to use this app I still feel that the Interface and the maps are very smooth and OEM like.
    So – I’ve mentioned the maps and interface so I’ll start there. Initially when you set this up you need to lock it to your hardware using a code the app generates. Now normally the end user would go to the web site and submit this code so you get the final ‘activation’ code. I tried briefly to see how this would work and found that not only was the web site talking about an older version but also PC and NavigatoR 2 did not appear in the activation list. Going from this I assume you must have to email them which may cause a delay.
    Other than that problem the installation was fairly straight forward although again there was no clear way to install maps other than coping them over…. which where large and comprehensive.
    That aside when you start the app your presented with a warning and then a very simple menu… which in its self was a bit annoying as I would like to see it go straight to the map.
    A couple of other map features I did like was the maps showing arrows where the one way systems where and even on round a bouts which way to go.
    When routing I found the up coming manuvour warnings very clear indeed and the voice faultless and very professional…. Even to the point where you are told what the road identification was verbally eg. A456 etc.
    The interface is skinable although take some playing as this is done through ini files for the most part so I see this as an area they could improve for the ‘out of the box’ users rather than their corporate ones who this is generally aimed at. One comment that CDRSkull made was that the OSK was cramped and I have to say I agree with him on this… also I found the app did not want to embed very well either having multiple windows. A simple wrapper may fix the problem here.
    The map is very easy to read and very well tagged with street names and a comprehensive set of quality POIs showing in most cases not just down to the type ( eg Shop ) but the details as well ( eg ASDA ) allowing for a very specific routing if you required it.
    The map controls can be activated by touching the top corner of the screen which I did find I missed some times as it was such a small area and ended up hitting the program menu which is activated by touching the map area. On these controls you can see the signal strength and TMC messages you may be getting.
    Now – TMC – this was the main reason I was interested in the app but unfortunately I just could not get a signal through my receiver and when I did it was from the wrong service. Unfortunately I have not been able to get a clear answer as whether the UK TMC is supported even though Navigon signed a deal with RAC Trafficmaster a couple of years ago. Over here the service has to be paid for where as over on the main land EU they get it free…. So a big minus here for me.
    Out of interest post code support is about the same in Destinator 3 so again another minus for me here as I was hoping it would be more comprehensive all though I did find the routing in general more accurate.
    The SDK support ( according to CDRSkull ) could be better and did not give the flexibility of the Destinator SDK how ever they did bundle an interesting ‘server’ ‘client’ feature allowing you to integrate tracking in to your own program. How ever for our selves in the CarPC world I think GPSGate is the best bet for this especially as this is exactly their latest feature and can be added to any GPS app.
    In all – I love it. It has a lot of areas of improvement and a number that it needs to improve on how ever when evaluating this we must remember this app is aimed at the corporate market rather than our selves therefore there is an expectation a lot of these areas would be addressed by the user writing custom software.
    So – I’m just waiting to see what Navigator 7 from Directions is like ( mainly because CDR is and I want to stick with his front ends ) but assuming that does not live up to expectations I may just part with some cash for this app and learn VB.net…
    For TMC – I’m more convinced than ever we need to find a online version from those free feeds out there and some way to feed it in to these apps but again although projects around this have started and stopped no one seems that interested so I guess I’ve got yet another project there too.
    In all – if your in the mainland EU you will not be disappointed if your can with some small funnies. Over here… well that remains to be seen as applications seem to be created with mainland EU in main and not the UK ….. even so far by companies based here which is a comment I have made before today.
    Terran
    Oct 2003
    Navigon Navigator review
    Hi Terran,
    I'm an old newbie in that, I registered and posted a couple of lines back in 2003 when I first built my MGB with a EPIA-M and lilliput screen but haven't been on line recently - if you do a search on my posts you'll see some pix.
    In the MG, I used PrymeNav but its 3 years old and without locating the disks, I think it may have been v1.0, worked well enough to get my son and I to the Nurburgring but no GB postcode search means its fairly limited here, and the small on-screen buttons meant it was always questionable whether using it was safe! :-(
    I've just ordered a Samsung Q1 tablet PC with a view to using it as a mobile PC and transferring between my MG and a Discovery (8" touchscreen) I use as my daily driver, it's a Tablet PC, 900MHz Intel M with 1GB mem and 60GB HD and was thinking of an upgrade on the software especially as my partner and I are driving down to Spain this summer, I liked your review of the Navigon as it reminds me of the professional system in my Audi and wondered whether to take the plunge or wait to see the reviews of Destinations 7.0, one thing that is key is the ability to import own POIs as the Disco is LPG and I'd like to locate stations via the Nav, do you know if both will support that?
    Also your screen shots are the same as the German site, I'm assuming the language support for English is there and very good?
    Finally, you're fairly local to me and if you wouldn't mind showing me the Navigon software, I'd welcome the chance to look at it before making a decision?
    very best regards
    Darren Jones
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    I asked the language question in another thread and it does do English, but Terran keeps posting German screenies
    Jan 2003
    Quote Originally Posted by autopia View Post
    Hi Terran,
    very best regards
    Darren Jones
    Yeh its got a number languages...... when I see D 7 I'll try and post a comparison, how ever if in doubt have a word with Oliver @ Cartft.com.
    Terran
    Constant Bitrate henkbliek's Avatar
    Dec 2002
    Netherlands
    Here a short screencapture of Navigator2 for the more English minded:
    white bream
    working on a trilogy: CARGO - UNIGO - MERGO
    CARGO = the Car Computer
    Intel Celeron M, [P]SDC, uBlox GPS, GPRS, WLAN, Silabs FM, RDS, TMC,
    Dual-audio, Onecable TFT, Microsize: 45 x 108 x 168mm (1.8 x 4.3 x 6.6")
    Jan 2003
    For those of you intrested in NavigatoR 2.....
    http://www.mp3car.com/vbulletin/1077972-post1.html
    Terran
    Jan 2006
    I've been using NCK5 for over a year now with no problems. The interface looks exactly the same as this.
    What's up with the new name and version?!
  1. Software Review: Windows XP Media Center 2005 Edition!
    By nFiniteTuning in forum The Review Palace
    Last Post: 05-01-2007, 12:54 PM
  2. Suggestion for the Software forum
    By Confused in forum Mp3car Forum Suggestions/Comments
    Last Post: 11-02-2004, 08:55 AM
  3. Please review my setup/thoughts
    By edrock200 in forum Newbie
    Last Post: 09-18-2004, 09:07 PM
  4. myHTPC Software
    By the_new_guy in forum Software & Software Development
    Last Post: 06-05-2004, 04:51 PM
