Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Hardware Review: License mount camera
  1. #11
    Jun 2007
    Quote Originally Posted by loginfailed View Post
    Just get a relay and use the reverse lights to trigger the relay. most reverse lights are positive polarity so do it like this
    bosch type SPDT (single pole double throw) automotive 30 amp relay
    terminal 85 to ground
    terminal 86 to your reverse lights
    terminal 30 to the power source you are using to power the camera
    terminal 87 to the power input on your camera
    when you put it in reverse the camera will turn on and it will go off when the car is not in reverse
    Relay info in case you need it:
    http://www.the12volt.com/relays/relays.asp
    actually my unit has a reverse dedicated set up but I connect my rear view without having to put reverse and show the reverse view, I wanted to show rear view any time durring normal drive ..... but my cam seem to be on full time can I do something to turn it off? thanks
  2. #12
    Feb 2004
    North Aurora, IL
    fusion brain + relays i think would be able to let u control it..but then thats some $$ that u would need to spend
    I wish i knew how to do fiberglass work...
  3. #13
    May 2007
    Quote Originally Posted by DodgeCummins View Post
    In my opinion all electronic devices wear out over time...so running it all the time would shorten its life.
    However power surges with constantly turning things on and off greatly shortens life span also.
    But in my case I just wired it up to the reverse lights...so it is powered when I am in reverse...and the screen switches to the reverse camera at the same time.
    In your case, I don't think running a camera 3 hours a day would be a big deal at all.
    thanks alot, hopefully i can get around to installing it, its been sitting in my room for about a month now... i think im going to just wire it along with my amplifier, so everything turns on with one switch, switch-> carputer/amplifier/rearview camera.
  4. #14
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by Octavio View Post
    You can do like I did..... Run a wire from your ACC 12V+ source to the camera. That way when you turn the key the camera turns on, when you turn the key off, the screen goes off. Remeber to put a fuse between the Acc 12v+ and the camera. In my case, I have a 15 inch screen for the rear on the way, so when that is down, I can not see behind me..... So when the car is on, I need my cam to be on....
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
  5. #15
    Aug 2009
    Pretty sweet! I just may have to do the same thing..... hooking up trailer hitches will be so easy.
  1. 120 deg Wide-Angle Rear View Reverse Camera off Ebay - REVIEW
    By tbird2340 in forum The Review Palace
    Last Post: 01-11-2005, 04:30 PM
  2. Building a Car Camera Mount
    By xBrady in forum General Hardware Discussion
    Last Post: 08-19-2004, 09:43 PM
  3. Multiple Hardware Questions (camera, DVD...)
    By GMCVOY in forum General Hardware Discussion
    Last Post: 07-25-2004, 03:45 AM
  4. Where to mount a video camera.
    By fluffy2097 in forum LCD/Display
    Last Post: 11-30-2003, 09:39 PM
  5. Flex-arm mount , good for LCD or keyboard
    By gizmomkr in forum Classified Archive
    Last Post: 02-19-2001, 04:17 PM
