Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 49
Thread: Griffin Powermate Review
  1. #31
    Mar 2007
    I've been running one of these for about six or seven months and I thought I would make some comments.
    1. Sometimes, just turning the knob registers as a push-turn. As far as I can tell, this tends to be more likely after pushing the knob for some other reason (e.g., a push turn, a push, or a push-hold). The good thing is that such an error usually only happens once, so subsequent turns are indeed registered correctly; only the first turn is interpreted as a push-turn. Also, it doesn't appear to be a function of the mechanical parts getting stuck in the "pushed" position. I believe this because the error will occur even if I pull up on the knob after it has been previous pushed down. It's a little annoying but I suppose you can't expect much for $20.
    2. Pushing on the knob will wake my Mac Mini from sleep. I don't think this is due to anything particular with the powermate, just a property of USB devices on Mac Mini's. Although, I suspect this has been a reason for at least one drained battery in my car. I think this can be resolved by connecting my USB devices to a hub that is powered solely by the power supply and not the mini so I plan to go that route eventually.
    Just my 2 cents...
  2. #32
    Nov 2007
    Can you assign it a function for holding it in for a set amount of time, say three seconds? I want to set one up to control a music program and have it be able to go from the control screen to the browsing screen by holding it in for 3 seconds.
  3. #33
    Constant Bitrate daclothe's Avatar
    Dec 2004
    i'm really only using it for volume right now, but it is the best 25 bucks i have spent. it does the job well, with a little bit of style in the process.
  4. #34
    Mar 2007
    Quote Originally Posted by hutacars View Post
    From what I understand, you can assign functions to the following inputs:
    • push
    • long push
    • turn left
    • turn right
    • push turn left
    • push turn right
    I don't remember exactly how long the "long" push is, but, the duration is not user definable (although, it might very well be 3 seconds).
  5. #35
    Maximum Bitrate Megalomaniac's Avatar
    Jan 2006
    The Colony, TX
    Quote Originally Posted by mustanglou View Post
    • push
    • long push
    • turn left
    • turn right
    • push turn left
    • push turn right
    iirc you can set how long a push delay is up to 3seconds
    also its no longer $25
    I guess we got lucky whomever got the good deal too
    screen name here use to be MegaloRESE15"
  6. #36
    kuo
    kuo is offline
    Variable Bitrate kuo's Avatar
    Jun 2003
    Greensboro, NC
    you can use the powermate along with girder and program any function you like ie double click, hold for 1 sec, hold for 2, hold for 3, etc.
    my car: 2003 g35 coupe, 2.5ghz c2d cpu, gigabyte micro atx mb, dsatx
    wife's car: 2004 honda accord coupe 2.4ghz p4 cpu, asus micro atx mb, opus 150
    company car: 2006 chevy avalanche 2.0ghz p4 laptop, cnx p1900
  7. #37
    Aug 2007
    Quote Originally Posted by Megalomaniac View Post
    I know, i ordered at $25 but was told they were out of the $25 specials and had to reorder at full price, not happy
  8. #38
    Oct 2007
    Quote Originally Posted by sgtpepperaut View Post
    works well when it does work.
    i have to replug it everytime i restart...its fine after stand by.
    I have the same problem... when I restart my computer I've to unplug and replug it in the usb port... have tried 1.5.3 drivers and also the last drivers available on the griffin website...
    Any suggestions??
    Thank you
  9. #39
    Dec 2004
    wow i got a black one off ebay for like 23 shipped...i had no idea that i got such a steal!
    @trinky have you tried devcon to shut it down temporarily before standing by? the 2.0 beta drivers have worked well for me and the whole "dim the LED when the volume is lowered" is kind of neat i guess!
  10. #40
    Oct 2007
    Is it possible to program the powermate so when you click, instead of muting, you lower the volume to say 30%, just like a "att" button on a regular car headunit?
  1. Griffin PowerMate? Can't get it to work... help please!
    By coachreed in forum General Hardware Discussion
    Last Post: 08-25-2009, 09:20 PM
  2. Griffin Powermate pics - let's see 'm guys!
    By R32 JUhl in forum Input Devices
    Last Post: 06-11-2008, 08:57 AM
  3. Griffin Powermate on GeeXboX?
    By UrbanSoot in forum Linux
    Last Post: 09-24-2007, 04:20 PM
  4. Replies: 2
    Last Post: 12-01-2006, 11:54 PM
  5. griffin powermate controlling gps (dest 3)?
    By alanp in forum Input Devices
    Last Post: 01-24-2005, 03:21 PM
