Page 5 of 5 FirstFirst 12345
Results 41 to 49 of 49
Thread: Griffin Powermate Review
  1. #41
    Nov 2006
    Worcester, MA
    Just got 2 in. E-Bay.. I paid $17(shipped) for one and $21(shipped) for the other.
    It's pretty handy. I wish i could change the cord placement to the bottom, as I want to mount these in the truck whenever I get the system setup.
    Anyone know of any other controllers like the powermate? I knew there was maybe an "Explorer" one. Looking at whatever is available, even though I do like the Powermate.
  2. #42
    May 2007
    Wichita, KS
    What version drivers are you guys using? i cannot get this thing to work for the life of me. xp, and it just keeps seeing it as a HID compliant mouse and refuses to let me change the driver.
  3. #43
    Maximum Bitrate Megalomaniac's Avatar
    Jan 2006
    The Colony, TX
    Quote Originally Posted by Lithoss View Post
    the cd that came with the powermat didnt work for me. I had to download the drivers/software from griffins site...latest one
    screen name here use to be MegaloRESE15"
  4. #44
    Nov 2007
    And if you are looking for the old drivers that seem realy hard to find I have them hosted here:
    http://gooki.orcon.net.nz/car_audio/...ate_1-5-3D.exe
  5. #45
    Variable Bitrate chris350's Avatar
    Aug 2007
    Queens, NYC
    Wow, digging this tread out thats been buried since 2007....anyways. powermates are not 19 bucks any more. I just got one for 40.00 with shipping.....this thread was so far buried it was in china...lol
    CarPc
    Project "Driver"
    Planning [99.9%]
    Parts Collected [98.5%]
    Installation & Fabrication [98%]
    Total Completion Level [96.9 %]
    http://www.mp3car.com/vbulletin/work...ct-driver.html
  6. #46
    Constant Bitrate popi79's Avatar
    Sep 2006
    Check this post.
    "Most of the users you'll see in this site are still learning specially me"
  7. #47
    Maximum Bitrate DaveDog's Avatar
    Mar 2004
    Greenacres, WA
    I cannot get the Powermate to work with Windows 7 unless the Powermate application is the active window. Probably going to gut the internals and substitute them with a mouse wheel.
    TruckPC - gutted, being used for test setup
    BoatPC - Update coming this spring
    BlazerPC - PS keeps killing battery
  8. #48
    Aug 2007
    Queens, NYC
    stick to XP when it comes down to CarPC's. Vista is crap and windows 7 is still new.
    CarPc
    Project "Driver"
    Planning [99.9%]
  9. #49
    May 2011
    Queensland, Australia
    Getting a Griffin PowerMate running on a new Windows Vista machine
    Hi all,
    I thought I'd share my tale of getting a Griffin PowerMate working under Windows Vista, since it was a very non-obvious way to go about it...
    I was considering buying a Griffin PowerMate to run under Linux, actually, so a friend with a couple spare loaned me one to try out. Keen to try it at work, under Windows Vista, I did the obvious thing and downloaded the PowerMate 2.0.1 "drivers" from the Griffin site (http://www.griffintechnology.com/sit...e_v2.0.1PC.zip) via the PowerMate Support page (http://www.griffintechnology.com/support/powermate).
    I installed the software, went to Start / All Programs / Griffin Technology / PowerMate, clicked the PowerMate and was greeted with the following:
    ************** Exception Text **************
    System.ComponentModel.Win32Exception: Access is denied
    at Griffin.Devices.Device.Open(String devicePath, FileAccess access)
    at Griffin.Devices.Device..ctor(String devicePath, FileAccess access)
    at Griffin.PowerMate.Device.HIDPowerMate.InitializeHI D(String devicePath)
    at Griffin.PowerMate.Device.HIDPowerMate.GetAll()
    at Griffin.PowerMate.App.PowerMateApp.FindPowerMates( )
    at Griffin.PowerMate.App.PowerMateApp.Main(String[] args)
    The management application was trying to open the PowerMate USB device directly, but was getting this exception because Windows Vista already had it open as a HID-compliant mouse. That explains why the mouse cursor would move left and right when I turned the PowerMate and clicked the left mouse button when I pressed the device.
    After more digging around I discovered that the PowerMate 2.0.1 "drivers" don't even come with device drivers! It's just a Microsoft .NET Framework 2.0 application to manage the devices and invoke Windows events on their behalf. Griffin probably assumes that you have had a previous PowerMate application installed (with drivers) and so don't even include drivers in the 2.0.1 package. Plugging a PowerMate into a virgin Vista machine will result in two devices appearing in the Device Manager (devmgmt.msc) with Vista's own default drivers:
    1. Human Interface Devices / USB Human Interface Device
    2. Mice and other pointing devices / HID-compliant mouse
    I eventually got the PowerMate working with the following convoluted procedure:
    • I located the older version 1.5.3 management software and drivers (PowerMate_1-5-3D.exe)
    • I started the installer but did not let it progress beyond the first page.
    • In Windows Explorer I went to my Temp folder (%LOCALAPPDATA%\Temp) and found the folder the installer had extracted all of its files in to (_is3D40 in my case, but this is probably random) and copied the "PowerMate Driver 1.5.3.msi" file out to my regular Install folder.
    • I cancelled the installer.
    Now, I right-clicked on the PowerMate Driver 1.5.3.msi file and using 7-zip extracted it to a folder "PowerMate Driver 1.5.3". This folder contains the needed PowrMate.inf file and a series of PowrMate.sys files (including two groups of identical files - go figure). In the Windows Device Manager (devmgmt.msc):
    1. NOTE: this procedure does not work on the "HID-compliant mouse" device.
    2. I double-clicked on the appropriate "USB Human Interface" device (look for VendorID 077D and ProductID 0410 in the Details / Hardware Ids property)
    3. On the Driver tab I clicked Update Driver...
    4. Click Browse my computer for driver software
    5. Click Let me pick from a list of device drivers on my computer
    6. Click Have Disk... and open the PowrMate.inf file you extracted above.
    7. Windows will give you a security warning because the driver isn't signed - install it anyway.
    If all has worked well so far, in Device Manager you should see a "Griffin PowerMate" device under the Universal serial bus controllers category.
    Run the PowerMate application again and you should finally have control of your PowerMate!
    NOTE: If you don't see the PowerMate icon in the task tray you'll need to find the PowerMate.exe process in Windows Task Manager, End Process it, and start it again.
  1. Griffin PowerMate? Can't get it to work... help please!
    By coachreed in forum General Hardware Discussion
    Last Post: 08-25-2009, 09:20 PM
  2. Griffin Powermate pics - let's see 'm guys!
    By R32 JUhl in forum Input Devices
    Last Post: 06-11-2008, 08:57 AM
  3. Griffin Powermate on GeeXboX?
    By UrbanSoot in forum Linux
    Last Post: 09-24-2007, 04:20 PM
  4. Replies: 2
    Last Post: 12-01-2006, 11:54 PM
  5. griffin powermate controlling gps (dest 3)?
    By alanp in forum Input Devices
    Last Post: 01-24-2005, 03:21 PM
