Your T7300 is a socket P. Impossible to stick in a socket M board. Just impossible. Not compatible at all.
By RAM timings I mean it has horrible reviews for being finicky with the RAM selections. The 945 and 965 in terms of stability for graphics, is the same. It is just marketing hype. Of course they arent going to say "well the 945 works just fine, but spend $200 on a new motherboard to buy this because it is marginally more
power efficient...".
This board I am pretty sure can use DVI and VGA output seperately. With the C2D installed, I am sure it would be speedy enough for the car even using the
onboard graphics. Maybe not for 1080i decoding for both screens at the same time, but high-def on a 7" screen is useless anyways.
Also for your speaker pop, that is just because your amp is turning on before the
sound drivers are loaded. No matter what card you choose (onboard or offboard), and the drivers are loaded after the amp turns on, then you will get a speaker pop. And why do you need 7.1 in the car anyways? Most have 4.0 or 4.1 (4 speakers FL, FR, RL, RR) and optionally sub lines (all use the same channel).
