Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 36
Thread: Mobile Wifi Roof Antenna
  1. #11
    Aug 2007
    What type of antenna is that?
    Someone has a URL?
  2. #12
    Maximum Bitrate Injector's Avatar
    Mar 2005
    Rockledge, FL
    Quote Originally Posted by st1mpy View Post
    Someone has a URL?
    did anyone think to look at the mp3car store? i think you might just find it there
  3. #13
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by Injector View Post
    That is were it is....... I just forgot to mention it, but you beat me to it, HEHE....
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
  4. #14
    Aug 2007
    tnx
  5. #15
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Yeah that's a nice if you have a GPS Serial Card.. Furhter investigation of the antenna revealed issues when using GPS and Wireless at the same time.
  6. #16
    ptk
    ptk is offline
    Singapore
    actually I use this particular antenna. I use it with 54G Wlan, GPS and UTMS all at the same time. No issue. they are discreet antenna elements at different frequency range
    this is my car pc. the 3 SMA at the left hand side are connector to the said antenna
    CarPC Ver 4 completed. Aopen i45GMT-HD, C2D mobile 2GHz. Photofast 64GB SSD. Novatel EU-850D
  7. #17
    Dec 2007
    would someone mind explaining to me how one might go about wiring this antenna (the one in the mp3 store) It appears it only has one cable to go to a receiver? I'm confused. Thanks in advance!
    P.S. Does anyone have any stats on how this antenna compares on the wifi end of things?
  8. #18
    ptk
    ptk is offline
    Singapore
    nsgrossman:
    there are 3 coaxial cables. not 1.
    what kind of stats are u looking for? as in the dB? 0dB
    it also depends on your WLAN card's output and if it supplies the bias voltage.
    kao
    Code:
    Mechanical construction details:
    Dimensions (W x H x D) 81 x 45 x 42 mm (without rod)
    Weight 255 g
    Housing material PA6
    Rod section 1
    Rod length 50 mm
    Rod inclination 74°
    Installation
    Environmental conditions
    Temperature range -40° - +80° C
    Protection class IP66 (acc. IEC 60529)
    GPS
    Frequency range 1.57542 GHz +-1.023 MHz, (L1-band)
    Return loss > 12 dB
    Impendance 50 Ohm
    Current consumption max. 30 mA
    Gain typ. 2 dBic
    Amplification 24 dB +-4 dB
    Noise figure < 2.5 dB
    Voltage supply 3 - 5 VDC (remote fed)
    Cable type RG 174
    Cable length 3000 mm
    Connector FME female
    CELLULAR
    Frequency range AMPS: 824 - 894 MHz
    GSM 900: 880 - 960 MHz
    GSM 1800: 1710 - 1880 MHz
    GSM 1900: 1850 - 1990 MHz
    UMTS: 1900- 2170 MHz
    Impedance 50 Ohm
    Load capacity max. 8 W pulsed acc. GSM standard
    Return loss > 12 dB
    Decoupling > 40 dB
    Rod wave 1/4
    Rod gain 0 dB
    Cable type RG 174
    WLAN
    Frequency range Bluetooth: 2400 - 2484 MHz
    IEEE Std. 802.11b: 2412 - 2484 MHz
    Impedance 50 Ohm
    Load capacity max. 1 W (acc. IEEE 802.11b)
    Return loss > 12 dB
    Gain 0 dB
    Cable type RG 174
  9. #19
    ptk
    ptk is offline
    Singapore
  10. #20
    Dec 2007
    ptk thanks for the response. as far as stats I meant more along the lines of a test by a user. This antenna compared to a similar one made only for wlan, which one is easier to set up/wire, and which one works better/farther. Once again, thanks for the response!
    Nate
  1. Tall Wifi Antenna
    By EBFoxbat in forum Wireless Communications
    Last Post: 11-22-2005, 07:43 PM
