Page 4 of 8 FirstFirst 12345678 LastLast
Results 31 to 40 of 79
Thread: diNovo Mini™
  1. #31
    Low Bitrate Chamberlin's Avatar
    Aug 2006
    Tucson, AZ
    Finding that it lags a little bit, and takes a second or two to come back to life sometimes, in all, not as sure fire as my old USB wireless keyboard, but then again, I am using a Linksys dongle, and not the included one... but I suppose I could try that for comparison.
    It is not a huge problem though. I am still perplexed as to why they didn't illuminate the blue words as I seem to use those as much as anything else. Definitely consider using the logitech software to re-map your windows explorer hot key to ALT-F4 for example. You can also remap the music key too, mine is tied to XM PCR. Too bad there aren't any more mappable keys though. Also you are probably are going to want to adjust the sensitivity down on the mouse movement too.
  2. #32
    Maximum Bitrate LinuxRacr's Avatar
    Jul 2003
    Loving this keyboard!
    My Car: 2001 Mazda MP3
    My OLD Carputer project: Here
    Completion Progress Bar: [**********100%]
    Current build! Here
    Completion Progress Bar: [*********99%]
  3. #33
    Maximum Bitrate jonessc's Avatar
    Nov 2006
    Wales, UK
    On the subject of booting before OS
    I use a Microsoft Bluetooth keyboard and mouse with the supplied dongle, and can access bios fine as long as I press a key on the keyboard 1st and wait a sec or 2 to give it time to power on before switching pc on then press esc to get to bios, works fine every time (including the boot menu)
    it doesnt work with by belkin dongle so now i use both, I hope this is the same with this, as ive just ordered one
    CarPuter Progress:
    Planning:-----> [||||||||||] 100%
    Hardware Buying:-> [||||||||||] 100%
    Software:-----> [||||||||||] 100%
    Installing:-----> [||||||||||] 100%
    Current Project= Making skins in photoshop...
  4. #34
    Maximum Bitrate tn6478's Avatar
    Jun 2006
    Houston, TX
  5. #35
    Maximum Bitrate fixerofallthing's Avatar
    May 2005
    Lawrenceville GA
    Just ordered mine. Thanks for the heads up.
    The Car 2005 Scion xB
    The Truck 2004 GMC Canyon
  6. #36
    Low Bitrate vtecfelon23's Avatar
    Dec 2007
    Baltimore
    anyone have any specs on the charger?
  7. #37
    Maximum Bitrate Caelric's Avatar
    Sep 2005
    Bellevue, NE
    Quote Originally Posted by vtecfelon23 View Post
    Input: 110-240VAC, 0.25 amps
    Output: 8VDC, 500mA
    Kind of a bummer that it puts out 8VDC, since I have 12VDC, and 5VDC in my car that is easy to tap into to charge the keyboard, but no 8VDC, and I'm kind of hesitant with just using a straight voltage regulator, as 12VDC to 8VDC might generate a bit of heat.
    2005 Infiniti G35 6MT Coupe Black/Black
    Core Duo CarPC
    CarDomain page
  8. #38
    Low Bitrate deeznudts's Avatar
    Oct 2007
    Trenton, NJ
    I don't know why everyone wants to charge it in the car. Sure it's convenient. But I charged mine first when I got it. I've been using it for almost two months now and haven't had to charge it yet. The specs say it's good for a month. So once every 30 days you bring it in the house and charge it overnight.
  9. #39
    Sep 2005
    Bellevue, NE
    Quote Originally Posted by deeznudts View Post
    I don't know why everyone wants to charge it in the car. Sure it's convenient. .
    Thats why.
    Core Duo CarPC
    CarDomain page
  10. #40
    FLAC -zip-'s Avatar
    Ontario/Canada
    Just got mine today, wow are the keys ever tiny
    Sound Stage
    Eclipse|MTX|Infinity
  1. Logitech diNovo Mini, SEXY!
    By JDMinPDX in forum General Hardware Discussion
    Last Post: 03-20-2008, 11:58 PM
