That's still pretty good. Just with services disabled? I have a bunch disabled but unfortunately ya can't ditchem all....Thanks for the update.
8 secs cold start with services disabled, booting into RR.
I expect it to get slower though as time goes by
Confirmed dual PCI riser is working. I've tested a souncard with a PCI ethernet, and a soundcard with a gfx card.
I'm running it with this case. http://www.e-itx.com/g-alantic-ga630ibk-a.html
Hows the onboard sound in this motherboard ?
like i said,
i have no idea, honestly i didnt even test it. It's disabled in the bios, and the drivers are not installed I'm running a PCI soundcard.
Wow, that is impressive! Mine takes 18 seconds and I thought that was exceptional.
Hmmmm, I just might take mine out and put it into my kids machine and buy this one...thanks for the writeup!
"Imagination is more important than knowledge." -AE
before you get too excited, I'm using a solid state drive which - probably accounts for minimizing a lot of that boot time.
I'm still excited LOL!
What SSD are you using and is it just a "plain" install or have you tweaked it in any way?
Also, I forgot to ask, will thing display video to both separate outputs? The reason I ask is that I had a dual display video card that only showed video on the "primary" output stream so I'm eager to know.
Google is your friend,yes it does.
P4 2.8 HT, 512Mb Ram, 60Gb 2.5 HD, M4-ATX, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,RideRunner, iGo8, Custom Freedom 2.1
Looks like I have found my next CarPC Mobo.![]()
If you only knew the power of the dark side.....
