Page 6 of 10 FirstFirst 12345678910 LastLast
Results 51 to 60 of 95
Thread: Jetway NC62K Review
  1. #51
    Nov 2008
    Quote Originally Posted by Machinehead View Post
    Are you getting decent boot times with Windows 7?
    It seemed a little slow in the limited testing I've done.
    I think it takes between 10 to 12 sec .
  2. #52
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    I think I might just ditch this MB for another socket AM2. In a CARPC USB is everything, and it just isn't working right.
  3. #53
    Jan 2006
    i have no issues with usb using 2 hubs, and the following devices.
    Hub 1 - Screen, Extention, Nulooq and GPS
    Hub 2 - Silabs radio, bluetooth, Carnetix 2140 and a audison bit one process.
    Direct - CD rom drive (2 usb heads, 1 for power, another for data.)
  4. #54
    Jan 2006
    did you set your opus to standby mode? If not it'll cut power after a certain time after sending the acpi
  5. #55
    Nov 2007
    PA
    Quote Originally Posted by swordfishunter View Post
    Yes it's set for standby mode and seems to go into S3 just fine. The documentation this board is very poor and some of the jumpers are just not included anywhere in the manual. I do NOT have powered hubs, I am running them right into the board. You think using powered hub's would solve this? This sounds like a power issue to you?
  6. #56
    Jan 2006
    It's worth a shot.
    I've just used an opus for a project to power a wifi router AND a mini projector. Disconnect everything usb and try again.
    Also maybe it's your touchscreen preventing it from going standby.
    Try hooking up a ps2 mouse, or keyboard, disconnect everything USB and try again
    how soon after going to standby did you restart it? try 2 mins, 5 mins etc.. see if you can actually get it to standby and resume on a shorter time then try from there.
  7. #57
    Nov 2007
    PA
    I've been using standby for months. It works. The USB devices hover are hit or miss upon restart. Even if I restart the computer completely they still have issues. I just walked to my car after it being off for 3 hours and the USB GPS is still lit up. Why do you think I am not going into standby? I am pretty sure I am.
  8. #58
    Jan 2006
    touchscreen is usually the culprit.
    Anyway I use hibernate and have no problems with USB
    I'm using a DSATX for the PSU with no issues.
    I'm also running a carnetix 2140 for usb hubs, which has recently crapped out...
    However, _all_ the usb devices i listed are still functioning properly even without the 5v.
  9. #59
    Nov 2007
    PA
    I don't see anywhere in DM to set the screen "Do not allow to bring out of hibernate".
    My old jetway board only had 4 USB on the I/O panel. I ran 4 more from the jumpers on the MB and it always worked fine. Wondering If I should throw my powered USB hub in and just try that. What's the point of having 8 USB ports on the I/O if they have this problem ya know? Why do YOU run the hubs and not just use the supplied ports?
    Another thought...I use an old SB Live sound card for the setup. Would this draw a lot of power away from the USB?
  10. #60
    Nov 2007
    PA
    Swordfishhunter
    "I'm also running a carnetix 2140 for usb hubs, which has recently crapped out..."
    This is just to power your hubs and screen etc...? This is not a PSU but just a DC-DC regulator correct?
  1. Jetway mobo's
    By kamikaze2112 in forum General Hardware Discussion
    Last Post: 04-04-2008, 11:05 AM
  2. XENARC 700 IDT Review and ...and I need help
    By hondamac in forum LCD/Display
    Last Post: 09-26-2007, 07:39 PM
  3. Fix for M2-ATX and Jetway!
    By andrewb in forum Power Supplies
    Last Post: 09-16-2007, 06:28 PM
  4. Replies: 14
    Last Post: 04-13-2007, 02:23 PM
  5. Jetway AMD Geode NX1750 vs Commell LV-668
    By Orbserver in forum General Hardware Discussion
    Last Post: 10-13-2006, 11:18 AM
