Page 7 of 10 FirstFirst 12345678910 LastLast
Results 61 to 70 of 95
Thread: Jetway NC62K Review
  1. #61
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Curious to a few things here...I had issue deciding on the proper chipset driver for this board. Are you using 3rd party or the one from the website, as well for video drivers?
    I am really trying to narrow this down. Thanks for your help.
  2. #62
    Jan 2006
    from the website. Make sure you upgrade the bios as well
  3. #63
    Jan 2006
    This is just to power your hubs and screen etc...? This is not a PSU but just a DC-DC regulator correct?
    Yes, i use it to power the screen cleanly, and the hubs, as well as LEDS, and Fans for the amplifier. I also use it to prevent amp thump.
    the SB Live is a PCMICIA card? It shouldn't draw alot of power from the usb. What PSU are you using?
  4. #64
    Nov 2007
    PA
    Quote Originally Posted by swordfishunter View Post
    the SB Live is a PCMICIA card? It shouldn't draw a lot of power from the usb. What PSU are you using?
    The SB Live is a general PCI card on a PCI flexible riser.
    I am using an AMD FX-62 dual core...It's all I had laying around. I know it might be overkill but I don't have any other CPU's laying around. I imagine this thing could be power hungry but by all calculations I have found it still shouldn't be pushing the Opus to it's limit. I haven't had any other glitches, problems, or anything other than this USB crap. I hadn't updated the bios yet because I read on another thread where someone was having the same problem as me and it didn't help. I will upgrade the bios tonight, and maybe try using a USB hub I have just to see if it makes any notable difference. Again, thank you for the help.
  5. #65
    Nov 2007
    PA
    Well I am pulling my hair out. I cannot update the bios. I figured since there is no onboard floppy support and supposedly USB boot support I'd be ok with my Sandisk Flash drive. I have tried everything. The bios see's the USB drive but doesn't boot to it. I have tried making it bootable drive with HP utility etc...How the heck can I update this bios then>?
  6. #66
    Jun 2008
    Seattle, WA
    I used the WinFlash utility, to flash from within Windows.
    http://www.jetwaycomputer.com/download/WINFLASH.ZIP
  7. #67
    Nov 2007
    PA
    Quote Originally Posted by kross View Post
    Thank you very much!
  8. #68
    Nov 2007
    PA
    Bios updated: Problems persist as usual
  9. #69
    Jun 2008
    Seattle, WA
    Have you tried disabling the USB enhanced controller interface devices in Device Manager, and just going with USB 1.1, as I mentioned earlier? It worked for me...
  10. #70
    Nov 2007
    PA
    So disable enhanced controllers in DM and revert to 1.1 with NO high speed enabled in bios?
  1. Jetway mobo's
    By kamikaze2112 in forum General Hardware Discussion
    Last Post: 04-04-2008, 11:05 AM
  2. XENARC 700 IDT Review and ...and I need help
    By hondamac in forum LCD/Display
    Last Post: 09-26-2007, 07:39 PM
  3. Fix for M2-ATX and Jetway!
    By andrewb in forum Power Supplies
    Last Post: 09-16-2007, 06:28 PM
  4. Replies: 14
    Last Post: 04-13-2007, 02:23 PM
  5. Jetway AMD Geode NX1750 vs Commell LV-668
    By Orbserver in forum General Hardware Discussion
    Last Post: 10-13-2006, 11:18 AM
