Page 9 of 10 FirstFirst 12345678910 LastLast
Results 81 to 90 of 95
Thread: Jetway NC62K Review
  1. #81
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Quote Originally Posted by cano View Post
    what i was trying to say was how can i get faster boot times and faster shutdown times.
    please help. i dont know what i did wrong. I have done my sys manny times.
    This is kind of general...I have already inadvertently taken this post off topic. I have a simple XP setup. No tiny xp or anything it loads lighting fast. Check out the OS optimization sections of this site. Use the S3 (standby) suspend if you can.
  2. #82
    Jan 2006
    4850e 0 That's what I have, 0 USB issues.
    Running on a DSATX.
    Let me reiterate again my devices, all on 2.0 have no problem. In fact, all usb ports are used up ! including 2 Hubs.
  3. #83
    Jan 2006
    also to add in, it runs a WD 10k rpm drive.
  4. #84
    Mar 2009
    @swordfishunter
    What ssd are you using?
  5. #85
    Jan 2006
    i was using a transcend SSD, however, it hibernated too slow - so i gave it up for a 10k rpm drive.
  6. #86
    Nov 2007
    PA
    I am using this one if you are curious. http://www.ocztechnology.com/product...ata_ii_2_5-ssd. They do hibernate very slow comparatively, however I use standby so It doesn't really matter.
  7. #87
    Jun 2008
    Seattle, WA
    Quote Originally Posted by Dougw133 View Post
    Well thank you for the advice. I am going to put an order in for the 4850e and go form there...I will report back.
    How is the new 4850e working out?
  8. #88
    Nov 2007
    PA
    Quote Originally Posted by kross View Post
    Had an issue with newegg. They wouldn't accept any of my credit cards saying they were all declined. So that ate about 2 days and they say there is no problem on there end...SO I just ordered through Amazon and wouldn't you know my credit cards work just fine. Waiting on it any day now, will let ya know.
  9. #89
    Nov 2007
    PA
    *Update*
    Recieved my "5050e" today as well as some updated ram (2gb 1066 mushkin). I popped the CPU in with the ram and it fired right up. I noticed instantly that my steering wheel controls were more responsive. The gps, which actually had been locking on for the last 4 weeks did not obtain lock while on my way to work. I have not plugged my wireless card back in either. There is notable difference however, so I can def. attribute my issues to power. I am at work right now, and will get everything running and do a final test tomorrow. I'll report back. So for, promising!
  10. #90
    Nov 2007
    PA
    FYI
    I flashed the bios in hopes of fixing the "USB Port 3" issue and it crashed. I flashed using the supplied utility from jetway (Awdflash). I have flashed many bios's before and never ran into the dreaded flash crash. Now I am without a carpc. Jetway offers NO support on the issue. They tell you to contact your supplier. What supplier (newegg) is going to or has the capability to replace a bios chip? This ridiculous! My brother screwed his asus board up with a flash and asus RMA'd the board even though it was over a year old and sent him a new one. Jetway implemented "Bios Recovery" back in 2007 and it did not make it onto this board apparently. Beware!
  1. Jetway mobo's
    By kamikaze2112 in forum General Hardware Discussion
    Last Post: 04-04-2008, 10:05 AM
  2. XENARC 700 IDT Review and ...and I need help
    By hondamac in forum LCD/Display
    Last Post: 09-26-2007, 06:39 PM
  3. Fix for M2-ATX and Jetway!
    By andrewb in forum Power Supplies
    Last Post: 09-16-2007, 05:28 PM
  4. Replies: 14
    Last Post: 04-13-2007, 01:23 PM
  5. Jetway AMD Geode NX1750 vs Commell LV-668
    By Orbserver in forum General Hardware Discussion
    Last Post: 10-13-2006, 10:18 AM
