I think this product would be good if you set your computer to go into standby when the ignition is off. This way, it runs off the second battery providing standby power for very long periods of time, without worry of draining your main battery. And it has the smarts to recharge your standby battery while the car is running.
Obviously the product was not designed for the application for which you are trying to use it. The product is designed as a true UPS system, where the main power is active almost all of the time, and it only needs to switch to backup power only occasionally.
-- Kevin
LinkBack URL
About LinkBacks
[/IMG]
