Results 1 to 3 of 3
Thread: Foxconn 45CSX vs Intel D945GCLF2
    Mar 2006
    Blog Entries
    1
    I found the Intel D945GCLF2 BIOS to be slow at POSTing and I heard that foxconn motherboards have a reputation for fast BIOS operations so I purchased a dual core Atom 45CSX from newegg.com for $70. These motherboards are extremely similar with the same audio chip, same COM1/Parallel port, etc so I will only list what's different between the two.
    Intel:
    one fan
    8 total USB connections
    Supports IDE
    3 pin system fan
    requires P4 power connector
    3 year warranty
    comes with 1 long SATA cable
    Foxconn:
    fanless
    6 total USB connections
    No IDE support, only SATA.
    4 pin system fan
    does not require P4 power connector
    1 year warranty
    comes with 2 short SATA cables
    approx $20 cheaper
    The Intel BIOS is very slow to navigate and slow to draw screens, it feels slow like an 8088 or XT processor from twenty-five years ago. The fastest I could get the BIOS to boot is 5 seconds after alot of tweaking.
    The foxconn BIOS is fast like we are accustomed to when navigating around. There's a lot more options available to turn things off, or do it manually. You can even program the BIOS to turn off your motherboard if the CPU exceeds a certain temperature. From power up I initially thought the BIOS only took 1 second to boot because that's how fast the BIOS information is shown on the screen before it starts loading from Windows. However when I examined closely the BIOS screen is black for 3-4 seconds prior so there isn't much of an improvement in BIOS times.
    The four pin system fan socket is new to me, and it is backwards compatible to the 3 pin system fan plug found on my Mo-Co-So computer case fan. However, with a 3 pin fan the foxconn M/B can no longer control the speed and causes the fan to run full blast. So now it runs louder until I can find a 4 pin replacement fan.
    The foxconn doesn't require a P4 power connector so you can't accidentally damage your motherboard/CPU which is good, and also saves you a few bucks from having to buy that separately.
    I've attached two pictures, one with the foxconn motherboard and M2-ATX power supply attached to the Mo-Co-So bottom case, and the other picture of the D945GCLF2 motherboard by itself.
    Here's a video with the Foxconn demonstrating how long it takes to boot from hibernate. Hardware: 512MB ram, 5400 rpm Seagate 60GB EE25 automotive SATA drive.
    Foxconn 45CSX taking 11 seconds from power on to Streetdeck software.
    [media]http://www.youtube.com/watch?v=dStymNdPRpk[/media]
    Conclusion: If you can live with 6 USB ports and planning on only using a SATA HD interface then this motherboard is a better choice over the D945GCLF2.
    Oct 2006
    this is the reason why before i got hybrid sleep working, i only use foxconn motherboards for carpc. I remembered trying to track down one of these a while ago when i was purchasing a new carpc, but there weren't any of these boards close to north america.
    I'm still using a foxconn motherboard (R10-S4 Barebone) with almost the same spec as your except with more sata connection. However the R10-S4's bios was disappointing compared to the CSX-45 in term of boot time. Then i figured out how to use hybrid sleep, which is now like 1 second bootup.
    Constant Bitrate Sleepyz0mby's Avatar
    Feb 2010
    PanamaCityBeach/NewOrleans
    holy crap 11 seconds !!!
    ive got to add that after i updated my d945gclf the post/bois was extremely fast as well.
    and after reading and a bunch of testing, i found the hdd is a BIG factor in resuming from hibernate. each hdd differ in how long the bios can initialize them and the read speed of a hdd is the bottleneck while writing to the ram.
    but 11 seconds! thats good stuff
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. Replies: 11
    Last Post: 07-04-2009, 04:35 PM
  3. Replies: 26
    Last Post: 05-06-2009, 10:16 AM
  4. Shuttle sv24 or fv24
    By michael_16j in forum General Hardware Discussion
    Last Post: 06-05-2006, 03:56 PM
  5. How is this motherboard? Intel board inside..
    By sspiro in forum General Hardware Discussion
    Last Post: 01-16-2005, 02:16 PM
