Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 57
Thread: Software Review - Breakaway Audio Enhancer (MUST HAVE!)
  1. #31
    Low Bitrate dune's Avatar
    Dec 2003
    Dallas, Texas
    Ok, I really want this app to work with my setup. Has anyone been able to get Centrafuse 3.1's volume controls to play nice with this driver?
    tango/dune
    Infiniti QX4 2002 project (done!... for now)
  2. #32
    Dec 2008
    Quote Originally Posted by konbaasiang View Post
    If you set the volume at -20 or above, the above does nothing. However, as you lower the volume below -20, that EQ starts activating, and at -30 it's full on, yielding a thick, warm bass boost!
    You can use this for ALL SORTS of things. For example, automatically boosting bass + mid bass as you turn the volume down, to overcome road noise and yield a full sound at any listening level..
    AND, you can use it to carve out the upper midrange when you crank the volume up to very high levels, protecting your ears and keeping it from sounding shrill.
    ///Leif
    usually i dont like audio enhancement programs because i believe in quality hardware and good source material (and flat eq's!), but a auto-adjusting loudness control sounds like a really cool idea, because my truck is a noisy enviroment that can drown out a lot of stuff... i might have to try it out sometime.
  3. #33
    Newbie SpaceMonkey's Avatar
    Jan 2004
    Adelaide, South Australia, Australia
    Forcing Line-In to go to Breakway Audio Enhancer
    I recently bought one of the Craig Brass DAB/FM Radio Modules and have its audio feeding into my sound cards line-in jack. It's sound quality is pretty good as is, but I always wanted to make it better by passing it through Breakway.
    I found out that the Breakway Audio Enhancer version doesn't support processing of line-in audio, whereas the Breakway Live version does but costs more - bumma. Alas, I then thought: what if I could do some sort of simultaneous recording and playback of the line-in, forcing the line-in audio to go through the standard wave out i.e. Breakway, which lead me to this nice C# code.
    All this code does is record the line-in audio to a memory buffer and play it back (almost) instantly via the wave out of a sound device. By making it play it back through the Breakaway Sound Device, it means the line-in audio can be processed by Breakaway!
    As expected, after some initial tests using the code's demo app, the quality of the Radio's audio improved dramatically after going through Breakaway. Also, you'll need to mute the line-in playback (not the line-in recording) for your sound card to prevent hearing the line-in audio twice.
    This trick could also be used for those who still use their Head Unit for their radio, CD, DVD etc or use their IPod/IPhone, by connecting its output to the line-in jack of your carpc. This way you can enhance their audio through Breakaway.
    konbaasiang, any chance of having this feature (or something similar) included in the up & coming carpc version?
  4. #34
    Maximum Bitrate Caelric's Avatar
    Sep 2005
    Bellevue, NE
    Anyone have any problems using this with CentraFuse?
    2005 Infiniti G35 6MT Coupe Black/Black
    Core Duo CarPC
    CarDomain page
  5. #35
    Feb 2007
    UK
    Unfortunately there are plenty of us with the same problem…..unable to adjust the volume but, apart from that, Breakaway really improved the sound quality on my car’s setup.
    You can always try a plug-in request on the CF forum!
  6. #36
    Sep 2005
    Bellevue, NE
    Hmm, is the lack of volume adjust the only thing? I use my head unit for volume control, so if that is the only problem, it is not a problem for me.
    Core Duo CarPC
    CarDomain page
  7. #37
    Jan 2004
    I dont use CF and never have before this (since I use my own custom frontend) but thought I'd have a crack at starting some sort of solution to getting it controlling breakaway's volume so all you CF guys can use it as well. Although I managed to prove its possible I ran out of steam/interest and didn't complete it - weak, i know. But, if anyone wants to continue developing what i've started, i've attached the code below.
    Anyway, here's what I did: Started by downloading the CF3 trial and SDK to see how it controls the volume, and noticed that CF has a CFMixer.dll in its Mixer Plugins folder. Then I noticed the SDK contains the code for this plugin, thus allowing anyone to change it.
    So, I had a play around with this CFMixer code to see if I could simply prove it was possible to get it controlling Breakways volume. I was able to butcher it to force it so CF can see a 'virtual' (for lack of a better word) mixer line for the breakaway volume and treat it as the default Master Volume Line i.e. CF see's Breakway as just another audio mixer line. This allowed CF to change Breakways volume (via the windows msg's mentioned previously in this thread) using CF's standard volume controls.
    I doubt anyone would want to use what I've done as it is since it doesn't work very well but its a start. Some of its problems are: The CF volume slider thingy in the bottom left of the screen doesn't work with it (i think cos it uses a different method for setting the volume, but it should be possible to trace & fix easy enough), its forced into WinXP mixer API mode since I dont understand the new & weird Vista/Win7 Mixer API at all yet, and its all pretty clunky.
    So, should anyone want to develop it further, here's the code:
    MixerModules.zip
    It's in VS2010 format, so you'll need this to open it.
  8. #38
    Feb 2007
    UK
    Just read your post, only after sending you the last message!
    Now on the way to post a request on Centrafuse forum see if they want to get involved, I think its better for me to leave code for those who understand it.
    Nice one SpaceMonkey.
  9. #39
    Jun 2007
    St. Louis
    Just out of curiosity...and this probably isn't possible due to latencies...but if using low-latency such as ASIO, would it be possible to monitor the MIC input and invert the lower level frequencies as a form of road noise cancellation? Possibly a "learning" feature that can pick up on repetitive noises and cancel those out adaptively (such as the droning of the exhaust, or the blasted sound from the tires - and I realize the sound of the tires would change constantly depending on road surface conditions, speed, etc. but that's the reason for the adaptiveness)
    Just a thought...I think that may be of some interest to carpc users which have noisy vehicles despite anti-noise treatments (mine used to be quiet....around 80k miles ago )
  10. #40
    Jan 2004
    Hmm, noise cancellation for your car - cool idea.
    I've created a windows service that can capture line-in audio and send it back out through the wave-out in near real-time (allowing line-in/mic audio to pass through breakaway), but there's still a 1/2 second delay. Like you said, the ASIO cards might reduce this delay to make it more feasible. However, I'd have no idea how to process the audio to extract & invert the certain frequencies/noise - sure its more than possible tho.
    Also, I'll release the code to my line-in redirector windows service once its debugged...
  1. TouchScan OBD-II Software - OCTech Forum Product Review
    By mezz64 in forum Mp3Car Blog Talk
    Last Post: 10-23-2009, 01:15 PM
  2. How do I get subwoofer working on D945GCLF motherboard?
    By Maheriano in forum General Hardware Discussion
    Last Post: 10-12-2009, 10:38 PM
  3. Review: Garmin MobilePC Windows Navigation Software
    By Fiberoptic in forum The Review Palace
    Last Post: 07-19-2009, 12:30 PM
  4. Audio Tuning via Software
    By RedGTiVR6 in forum Wiki Discussion Threads
    Last Post: 02-09-2008, 11:28 PM
