Page 10 of 14 FirstFirst 1234567891011121314 LastLast
Results 91 to 100 of 137
Thread: 120 deg Wide-Angle Rear View Reverse Camera off Ebay - REVIEW
  1. #91
    Maximum Bitrate hd54321's Avatar
    Jun 2004
    Los Angeles
    Quote Originally Posted by kefka_killer
    Before you go out spending money, I would hook up the camera and see what the picture is like. If its pointing straight out wouldn't you lose your sense of relativity. IE you don't know how close you are to your bumper because you can't see it. Also you would have to rely on depth perception purely, and with a wide angle camera would get tricky and take some getting used to.
    Its been said before but I would go underneath the tailgate handle, or maybe even in the third brake light on the cab. It wouldn't let you see exactly where your bumper is, but the high up perspective plus the wide angle would let you see both corners of the tailgate and you can basically estimate that the bumper is aroud 5in further back from the tailgate, though estimating sort of defeats the purpose of a camera. Just another idea though.
    Thanks for your suggestion - because of what you said, I'm not going to mount the camera in the keyhole anymore. You're right, there is no point to having the camera point forward, it won't show you how close you are to the car behind you when parking. I've purchased a camera similar to the OP with adjustable rings, I'm going to mount the camera above my license plate facing down at an angle so I could see the rear bumper. The problem is getting the camera at the best angle to give me a good mix of seeing what's behind me and the bumper below.
    -HD
  2. #92
    Raw Wave tbird2340's Avatar
    Oct 2003
    Poland, OH
    Quote Originally Posted by Dominik
    If you were willing to ricey and put a wing on the back it would make things easier
    Not a chance....
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
  3. #93
    FLAC muldrick's Avatar
    Jun 2004
    South-Central PA
    TBird, do u intend to use this as a backup camera or a rear view "mirror". (Mines gonna be a rear view "mirrior, cause that's where my screen is, SUV)
    If you're not gonna use it as a backup camera, put it by the high mount brake light? or "in" the high mount brake light?
    How about putting it inside one of the taillights? (Get a used lens and mess with that)
    Just my crazy thoughts...
    AtmosUSA.biz, E-Cig Mods
    "A great smoking alternative"
  4. #94
    Oct 2003
    Poland, OH
    Well my intentions are to help when backing up.. Being that I have a truck it is VERY hard to tell how far away I am from cars when backing into parking spots. I'm not sure if mounting it high in my third brake light will work or not... I plan on mounting it into my hitch for the first try out location..
    I just got back from getting the conduit.. Hopefully I can get that done today. I already have the camera mounted into the hitch cover. It looks great. One problem... The nut it came with doesn't thread tight.. Yea.. Totally sucks.. I go to tighten it and it just keeps turning. Lowe's didn't have a 15/16" nut so I dunno what I'm gonna do about that.
  5. #95
    Jun 2004
    Los Angeles
    Screeeeeeenshots!!!!! (I also can't believe this thread is 95 posts long!)
  6. #96
    Constant Bitrate RPI Geek's Avatar
    Oct 2004
    Schenectady, NY
    Quote Originally Posted by tbird2340
    If the threads on the cam just end, or if they're stripped at the end, you only have to put a washer in between the hitch cover and the nut so that it still catches the (good) threads. If the threads are just gone, try getting/making a spring clip in place instead but be warned that it might not come off without breaking the hitch cover!
    I'm talking about a plate of spring steel cut with a hole cut just a little bit smaller than the camera body, with radial cuts going away from that hole, and you just push it down over the camera body so that the metal bends up and won't come back off.
    Or you could just glue it.
    Old plans out the window because of an accident .
    Have: M1-ATX, EPIA M10000, 256MB, 60GB 2.5", slim slot load DVD
    Need: Time, HU integration, ideas for Lilli
  7. #97
    Oct 2003
    Poland, OH
    Quote Originally Posted by hd54321
    I know... The title says "Review" and I have yet to "review" it..
    I have the conduit run and the camera installed. I just have to go get some wire and then I'll be all set. I'm liking the way it looks in the hitch I just hope the results are useable...
  8. #98
    Raw Wave BoyNextDoor's Avatar
    Aug 2004
    Walden, NY
    hope to see some pics soon, so maybe i can get one too...
  9. #99
    Oct 2003
    Poland, OH
    Two quick questions...
    I'm using an end from an AC adaptor that fits into the camera power. I'm just going to snip the ac end off and strip the two wires back.
    Question 1: How do I tell which one is power and which one is ground?
    Question 2: I'm going to tie the power wire into one of my PSU's YELLOW (12V) wires.. Can I just ground the other wire to my chassis or should I also run a ground wire to one of my PSU's BLACK (ground) wires..
  10. #100
    Constant Bitrate old_lou's Avatar
    Oct 2004
    UK Midlands
    If its to near the ground will you get it dirty very quickly and have to keep cleaning it, as flat backed vehicles create a small vacuum behind them and suck up the gunge of a wet road (asuming its outside the motor).
    sorry if this is a repeat not got time to read all the posts just an observation.
    EPIA MII: 512m Ram: LinITX 8" Touch Screen: Carnetix P1290 PSU: 802b PCMCIA Wireless card: Slot DVD Player: Touchpad: Wireless Keyboard: BU303 GPS Mouse:
    Win 2000: RoadRunner Front End: Michelin Mapstore GPS: Netstumbler:
  1. Rear view camera and dazzle usb
    By muldrick in forum Input Devices
    Last Post: 11-06-2004, 03:32 AM
  2. rear view camera
    By lasteclispe in forum LCD/Display
    Last Post: 10-21-2004, 11:00 AM
  3. Rear View Camera
    By 00GMC in forum General Hardware Discussion
    Last Post: 10-03-2004, 02:42 AM
  4. Rear camera view switcher (automatic)
    By M^ck^y in forum General Hardware Discussion
    Last Post: 09-07-2004, 06:40 AM
  5. Have video camera for rear view - which program?
    By nxt125 in forum Software & Software Development
    Last Post: 08-15-2002, 12:25 AM
