Page 11 of 14 FirstFirst ... 234567891011121314 LastLast
Results 101 to 110 of 137
Thread: 120 deg Wide-Angle Rear View Reverse Camera off Ebay - REVIEW
  1. #101
    Constant Bitrate RPI Geek's Avatar
    Oct 2004
    Schenectady, NY
    That's one reason to try making it waterPROOF rather than just water resistant, so that you can just hose it off.
    Old plans out the window because of an accident .
    Have: M1-ATX, EPIA M10000, 256MB, 60GB 2.5", slim slot load DVD
    Need: Time, HU integration, ideas for Lilli
  2. #102
    Tbird, you'll need a multimeter or continuity tester to tell which wire is which. You can make a makeshift tester using a light bulb and a battery. attach a wire to the negative end of the battery. Then attach another wire to the positive end of the battery and one of the contacts on the light bulb. Attach a 3rd wire to the other contact on the light bulb. Now strip the two remaining loose ends of the 1st and 3rd wire. Also strip the ends of the connector. Then insert one of the loose wires inside the center of the connector. Finally touch the remaining loose wire to the stripped ends of the connector. Only one will light the bulb and that one is the positive. I don't know if I would attach the camera to the psu, but if you do, attach the negative side to the black wire, the chassis may work, but the wire is a better choice.
  3. #103
    FLAC muldrick's Avatar
    Jun 2004
    South-Central PA
    Quote Originally Posted by Giwo
    Boy, that confused me (no offense )
    U probably allready have a multimeter (If not, get one. You'll allways use it)
    With the camera hooked up (the way it was when u had it working), probe each wire the following way: One lead of the MM to one wire, and the other lead to the other, you can tell which is positive by the meter reading, it'll show a positive or a negative value. If it reads negative, reverse the probes, when it reads positive...the one that you have the red lead too (from the MM) is positive.
    AtmosUSA.biz, E-Cig Mods
    "A great smoking alternative"
  4. #104
    Muldrick, No offense taken. Actually it is a very simple circuit, but I even realized when I wrote it that it seemed complicated in the description. A picture would have made it simple, and I agree about buying the meter. The only problem is if he hooks the camera up the way he had it working the power has to be plugged in where the connector with leads would go, so he can't read the voltage. He would have to set the meter to impedence. Insert one lead into the center of the connector and then probe the two stripped ends with the other. The positive lead would be the one that registers. If your using a meter with a needle the needle will swing all the way to the right. If you using a digital meter it will probably register 0 which just means there is no impedence.
  5. #105
    Raw Wave tbird2340's Avatar
    Oct 2003
    Poland, OH
    It's Ok.. I had already tested it w/ a multimeter before anyone replied.. Just snipped the end off, stripped the wires, and plugged it in. Then I put the probes on the wires and got 12 + for one then switched the probes and got 12 - so I knew which were pos / neg..
    I got the install complete.. Didn't have a chance to take any pics but I will tonight / tomorrow..
    I ran into a speed bump when I went to plug in the Lilliput cable for composite input. It's a USB adaptor and I couldn't plug it in because the plug kept hitting my cigarette lighter.. I ended up having to cut out my cig lighter to make it fit.
    The picture quality is excellent in daylight. In darkness you can't see jack. This was just sitting in my driveway so I'm not sure if it will be any better when there are street lights and what not..
    I'll post some more later...
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
  6. #106
    Jun 2004
    South-Central PA
    Quote Originally Posted by tbird2340
    I don't see any as it is
  7. #107
    Oct 2003
    Poland, OH
    I meant that it was dark in my driveway.. Not "this is a picture of how dark it is in my driveway"
    Then I meant I'll post more info later...
  8. #108
    Maximum Bitrate hd54321's Avatar
    Jun 2004
    Los Angeles
    Try purchasing some cheapo - not so ricey looking - foglights you could place next to your hitch. You could setup some sort of relay that would turn on the lights whenever it senses that your reverse lights go on. This would give you a better picture at night.
    Another solution is to purchase and install one of those IR illuminators they sell on eBay (here is an example) and mount that next to your hitch.
    Also - post pics!!!!
    -HD
  9. #109
    Variable Bitrate rgardjr's Avatar
    Oct 2003
    I saw this today and thought of you:
    It's a locking tailgate handle. I thought you might beable to put a camera in the hole instead of the lock. I didn't see one made for your truck by this manufacturer though. Also, this is the camera I've been eyeing for my backup project:
    http://cgi.ebay.com/ebaymotors/ws/eB...category=50073
    It's quite a bit more expensive than the others but I think the lower lux rating makes it worth it. Just wanted to throw another idea out there.
    '03 Sierra Denali
  10. #110
    Oct 2003
    Poland, OH
    If those screen shots are actual... That camera looks sweet at night.. With mine you can barely see anything.. I don't really mind it though..
    I will post pics tomorrow. I promise!
  1. Rear view camera and dazzle usb
    By muldrick in forum Input Devices
    Last Post: 11-06-2004, 02:32 AM
  2. rear view camera
    By lasteclispe in forum LCD/Display
    Last Post: 10-21-2004, 10:00 AM
  3. Rear View Camera
    By 00GMC in forum General Hardware Discussion
    Last Post: 10-03-2004, 01:42 AM
  4. Rear camera view switcher (automatic)
    By M^ck^y in forum General Hardware Discussion
    Last Post: 09-07-2004, 05:40 AM
  5. Have video camera for rear view - which program?
    By nxt125 in forum Software & Software Development
    Last Post: 08-14-2002, 11:25 PM
