Page 2 of 14 FirstFirst 123456789101112 ... LastLast
Results 11 to 20 of 137
Thread: 120 deg Wide-Angle Rear View Reverse Camera off Ebay - REVIEW
  1. #11
    Maximum Bitrate R32 JUhl's Avatar
    Nov 2004
    North Atlanta
    Quote Originally Posted by jcdillin
    Ouch, yeah if you didnt check to make sure of the polarity coming from the adapter it could have definitly roasted the camera.
    I'll second that.
  2. #12
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by tbird2340
    Ok.. I have one of those adapters that go from 120 to a variety of volts. I set it to 12V and alligator clipped the wires together.. I got nuttin. Flipped the polarity switch.. Still nuttin...
    The ONLY thing that I have a question with is... If the polarity was wrong when hooked up could it have jacked it up and then when I switched it to the correct polarity it not matter because it was jacked up?
    I was going to say a that if you look at the power supply that was supplied, it is showing tip negative (ground) which is the opposite to which it looks like you and jcdillin assumed.
    as to whether you have burnt it out, depends on the quality of the camera, a good one would of had polarity protection.
  3. #13
    Maximum Bitrate hd54321's Avatar
    Jun 2004
    Los Angeles
    FYI - the adapter might not be pulling the right amount of amps to power the camera.
    1.) Figure out the positive and negative wires from the camera
    2.) take an extra Molex adapter (splitter) you may have lying around for your computer and cut off one of the Molex ends
    3.) Identify the 12 volt and ground wires on the Molex. (I think the yellow wire is 12 volt and the red wire is 5 volt - don't take my word for it, do some verification yourself)
    4.) Connect the positive camera wire to the +12v wire of the molex connector and the negative to negative
    5.) Connect the other end of the Molex to your computer power supply and power up your computer
    6.) Enjoy.
    If you've done these steps correctly and still don't see anything from the camera, than it's probably fried. Good luck.
    -HD
  4. #14
    Nov 2004
    North Atlanta
    Quote Originally Posted by Enforcer
    http://www.ksoffice.com.tw/ebay/US/C...weradaptor.jpg
    Hmmm... to me that says tip positive, outside negative...
  5. #15
    Raw Wave tbird2340's Avatar
    Oct 2003
    Poland, OH
    FYI - This powersupply WAS NOT supplied. The only thing that came is the camera.. That is it.. No manual / instructions.. And NO PS...
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
  6. #16
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    and the picture of the power supply said center positive as well.
    edit: heh, dangit I aways do that.
    肚子笑痛了
    S60 Install
  7. #17
    Oct 2003
    Poland, OH
    Quote Originally Posted by hd54321
    6.) Enjoy.
    -HD
    NOOO!!!!!! Did that and still nuttin.. I didn't plug the video cable in to see if I get anything from it but I hear nothing or see nothing from the camera that lets me know its getting any juice...
    Also, when I hooked it up I got no sparks no smell no nuttin to indicate it was fried... Maybe I just got a bum cam??
  8. #18
    Raw Wave BoyNextDoor's Avatar
    Aug 2004
    Walden, NY
    Maybe...
    I would have went the other route first though. Would've soldered together a "converter" for RCA to regular adapter jack, and plugged it in that way, befor snipping the cable off. Now it's too late. Send this guy a couple of emails, and see weather he exchanges it, beecause i think the cam i F***ed up.
    Attila
  9. #19
    Nov 2004
    North Atlanta
    Ok... I'm the newbie here, so this may be a silly question - but why haven't you plugged in the video cable to verify the camera is/isn't functioning?
  10. #20
    Oct 2003
    Poland, OH
    Quote Originally Posted by BoyNextDoor
    Maybe...
    Attila
    Well yea... I woulda done a lot of things different.. First off.. I have one of those adapters that has numerous plugs on the end and you can set the voltage on it.. I woulda just plugged it into the cable but I didn't realize I even had that until I snipped off the end..
    On my AC/DC apapter it has a polarity switch.. How am I supposed to know which one to leave it on? It switches power / ground - ground / power.. And I've used this to test LED's before and it doesn't fry them when I have the switch in the wrong spot.. It just doesn't light them up??
  1. Rear view camera and dazzle usb
    By muldrick in forum Input Devices
    Last Post: 11-06-2004, 02:32 AM
  2. rear view camera
    By lasteclispe in forum LCD/Display
    Last Post: 10-21-2004, 10:00 AM
  3. Rear View Camera
    By 00GMC in forum General Hardware Discussion
    Last Post: 10-03-2004, 01:42 AM
  4. Rear camera view switcher (automatic)
    By M^ck^y in forum General Hardware Discussion
    Last Post: 09-07-2004, 05:40 AM
  5. Have video camera for rear view - which program?
    By nxt125 in forum Software & Software Development
    Last Post: 08-14-2002, 11:25 PM
