Page 5 of 14 FirstFirst 1234567891011121314 LastLast
Results 41 to 50 of 137
Thread: 120 deg Wide-Angle Rear View Reverse Camera off Ebay - REVIEW
  1. #41
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Quote Originally Posted by muldrick
    Anyone know the amps coming from a car? The car power would probably fry it right?
    What about the amps coming from the Opus90W?
    It's my understanding that DC powered devices pull only the amount of amps that it needs. If your PS doesn't put out enough, it won't work. But if you go over the required amps, it shouldn't be a problem.
    Tidder
    Try RevFE
  2. #42
    Raw Wave tbird2340's Avatar
    Oct 2003
    Poland, OH
    Quote Originally Posted by rando
    Definitely don't snip the wire on the new one. All the connections can be made up cleanly through the RCA connector. You should be able to get a safe regulated 12V from you PC power supply.
    Please explain to me how in detail. What am I supposed to do / use?
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
  3. #43
    FLAC muldrick's Avatar
    Jun 2004
    South-Central PA
    Quote Originally Posted by Tidder
    Anyone else agree with this? Too many amps won't fry it?
    I don't doubt you Tidder, just like to hear more on that.
    AtmosUSA.biz, E-Cig Mods
    "A great smoking alternative"
  4. #44
    Sep 2003
    New Mexico, USA
    Heh, PolkAudio agrees with me.
    " 'A' is for amperes, a measure of electric current. How much is enough? We like to say that having too much amperage is like having too much money."
    http://www.polkaudio.com/car/faqad/a...ticle=glossary
    Only time you need to worry about too much amperage, I guess is when you're trying to grow Marijuana.
    Google search found "cultivating marijuana". Here's an excerpt.
    "...too much amperage may damage cells and or stunt growth..."
    Tidder
    Try RevFE
  5. #45
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    ! yes like I said in my last post, too many amps wont damage it. it's the voltage that matters.
    Just go to radio shack and purchase this
    http://www.radioshack.com/product.as...t%5Fid=274-319
    Then just solder the wires coming from whatever your going to power the camera with and you'll be set.
    Edit: just make sure you are getting center positve from that new connector before you plug it in.
    肚子笑痛了
    S60 Install
  6. #46
    Oct 2003
    Poland, OH
    Quote Originally Posted by jcdillin
    How do I do this?
  7. #47
    Sep 2003
    New Mexico, USA
    voltmeter.
    Tidder
    Try RevFE
  8. #48
    May 2003
    Miami, FL
    otherwise known as a multimeter, they can be had for as cheap as $20
    肚子笑痛了
    S60 Install
  9. #49
    Jun 2004
    South-Central PA
    Right, you can probably get one at Walmart for 10 bucks. Strip the wires on the power suply, hook up the voltmeter and plug in the powersupply. The voltmeter will read "-12.00" or "12.00". When the positive lead (red) of the voltmeter is on the positive of the PSU it will read "12.00", if it is reversed it will read "-12.00"
    Then you'll know which one is the positive lead, get to barrel plug, hook up that posive lead to the center pole, and the negative wire the ground pole.
  10. #50
    Oct 2003
    Poland, OH
    Got the new camera today... Wow is this seller quick. I contacted him Saturday and I got a new one today.. Unreal...
    Plugged it into a 12V DC adapter I have and it worked. I didn't have time to really check out the quality and what not but I will say this..
    I don't think it will look that good in dark situations. It was very grainy in low light.. I think it will do just fine though..
    Now, I have to think of two things.
    1. Where to mount it (I have a truck so I can't put it in a keyhole of a trunk).
    2. How to run the RCA cable to my Lilli (again since I have a truck I will have to run the wire all outside and find a way to get it inside).
    Ideas for each of these would be great..
  1. Rear view camera and dazzle usb
    By muldrick in forum Input Devices
    Last Post: 11-06-2004, 03:32 AM
  2. rear view camera
    By lasteclispe in forum LCD/Display
    Last Post: 10-21-2004, 11:00 AM
  3. Rear View Camera
    By 00GMC in forum General Hardware Discussion
    Last Post: 10-03-2004, 02:42 AM
  4. Rear camera view switcher (automatic)
    By M^ck^y in forum General Hardware Discussion
    Last Post: 09-07-2004, 06:40 AM
  5. Have video camera for rear view - which program?
    By nxt125 in forum Software & Software Development
    Last Post: 08-15-2002, 12:25 AM
