Results 1 to 10 of 19
Thread: DWW-750J Motorized Screen-Full Review
    Maximum Bitrate techy101's Avatar
    Minneapolis, MN
    UPDATE: One other item of note that I have noticed with this screen is that it does not seem to have any form of onboard memory to save your settings once it closes. So as is mentioned in this thread, it will always open to the same position, and at the default brightness.
    Ok, so as promised in another thread, here is my review of the DWW-750J. If anyone else has one of these units, please post your reviews, opinions, etc... in here.
    OVERALL RATING: 8 out of 10. Very Good
    Ok, so I received my new DWW-750J in the mail today. Marina at Digital World Wide has been wonderful helping me out with my less than adequate DWW-700M. So thanks again for all your help. According to Armen it uses the same Hitachi LCD panel as the Lilliputs, but a different VGA controller. Which I hope means that it won’t be subject to all the problems I’ve read about the Lilli’s. Now on to the review:
    After opening the box I found the following:
    -DWW-750J Screen
    -TouchKit 3.1.5 CD
    -Barrel connector for power
    -Remote
    -Antenna for TV tuner
    There was no manual included. After talking to Marina she said that the unit doesn't come with one, but Armen is working on writing one for it. (this may be the reason it's not being publicized much right now on their site, but that’s just speculation on my part)
    A manual would be very helpful because the unit is laid out a bit odd.You can see the back of the unit in this picture. I forgot to take my own pictures before I installed it, so we'll work with Armen's.
    First Impressions:
    The unit feels much more durable than the 700M, and is all metal construction instead of the plastic front that the 700M has. One thing that struck me as a bit odd is the absence of a back plate. Not a big deal really, just strange. Another odd thing is that the TV tuner card (not shown in the pictures) actually sits on top of the unit with sticky tape, and has a ribbon cable attaching it. I assume this is because it was added in later when it was too late to put the whole card inside the unit. This is a bit cumbersome, but not something terrible IMHO.
    The USB cable is hardwired into the unit itself but all the other connectors are plugs on the back of the unit. Power is supplied through the barrel connector. Red to battery+, Black to Ground, and that funny yellow wire that is hardwired to the unit goes to ACC. This is where a manual would have come in handy, but after a bit of tinkering I figured it out.
    The unit has a VGA connector, S-Video input, Composite input, and what I'm assuming to be a stereo pair of audio Outputs for the TV tuner. There are also three 1/8" Mini Jacks on the unit that I'm not sure of their use, I'm waiting to hear back from Armen on that.
    So I went out to the car after figuring out the wiring of the unit and started the install.
    Installation was a piece of cake. You have more depth for the screw holes on the sides than on the 700M, which meant I didn't have to worry about finding or cutting short screws again.
    Once installed I started to tinker and figure the unit out. The front panel of the unit looks like this. The buttons are a bit sensitive and it is real easy to double-clutch them. This unit does offer an Auto-Open/Close function, which is controlled by the "Manual/Auto" switch. When set to Manual the unit opens and closes only but pushing the open/close button. When set to Auto the unit opens as soon as that ACC line has power, and closes approximately 5-10 seconds after it looses power. The screen stays on after you close the unit if there is still a signal which seems a bit odd, but the unit auto-powers down if the signal disappears, and auto-powers on when it receives a signal. This can be disabled by just turning off the power.
    I know that I've been mentioning a lot of tiny things that aren't so great about the unit, but they are tiny things. Now to all the good stuff
    The motor used in the unit is much more solid, and powerful. It opens and closes smoothly, and quickly. I LOVE that it turns side to side. Although it's a manual adjustment, it makes viewing SO MUCH EASIER.
    It's much less flashy than the 700M, and on that note, there are no annoying LED's that stay on all the time or any crap like that. Although I did like having the Clock since I had to take mine out for the top screen.
    The image quality is superb. with a great viewing angle, and the colors are very vibrant. It is just as bright as the 700M, but not washed out, and the "brightness" adjustment actually adjusts the backlight and (I think) the LCD "brightness" together instead of leaving the backlight at full like the 700M.
    The Touch screen is very responsive, accurate, and stable. It's not having any of the issues that I had with the 700M like loosing calibration, totally quitting, EEPROM errors, etc...
    I have not yet tried out the TV tuner or the two video inputs, so I can not comment on these.
    Overall I really like the unit. It gets an 8 out of 10 from me. Only loosing points for the small weirdisms like the backplate, not shutting off the LCD when closed, and TV Tuner being outside the unit. I would recommend it to anyone looking into a motorized 7" TS.
    I will post again after about a week or so of use to add any other thoughts or things that show up.
    Again, please post your own thoughts on the unit if you have one. I would like to hear what other people think
    Here are a few pics of the unit installed. I had to cut a tiny bit to make it fit, but not too much. I had the brightness turned down to 15 for night driving.
    EDIT: Just got this from Armen. It's a list of the inputs/outputs for the unit on the back panel.
    From left to right:
    1.SPEAK OUT(EAR PHONE, AUX TERMINAL)
    2.AUDIO RIGHT(RCA TYPE, WHITE)
    3.AUDIO LEFT (RCA TYPE, RED)
    4.AUDIO IN (ONLY PC MODE, LCD TV SPEASKER)
    5.VIDEO IN (RCA TYPE, YELLOW)
    6.S-VIDEO (SUPER VIDEO)
    7.VIDEO OUT/DIVERSITY INPUT
    8.RGB : PC VGA CARD.
    9.POWER / DC 12V IN : 12V 3A ABOVE
    Both Screens Open
    Up Close Open
    Closed
    Maximum Bitrate djXternal's Avatar
    Jul 2004
    Tampa, FL
    well i think its a great screen taking almost too days to install though, the way my dash is designed i really cant have the screen open to a full right angle, unless i tilt the HU and screen unit downward, in which case my plastic dash pieces dont fit... so if anyone knows of anyway to have the screen stop at a slightly tilted forward position instead of opening to a right angle let me know
    Debating on installing a carpc in my Jeep.....
    Minneapolis, MN
    Why not just hit the tilt button once after it's open?
    Jul 2004
    Tampa, FL
    because the tilt buttons do not work until the screen has reached it full open at a right angle, and where it was positioned kept the screen almost 1mm away from reaching that, but with some brute force and really tight screws i got it working now
    Minneapolis, MN
    Lol, I'd like to see pics.
    Jul 2004
    Tampa, FL
    ok ill go take some and put them up in about 10 minutes
    Jul 2004
    Tampa, FL
    here they are...
    Raw Wave BoyNextDoor's Avatar
    Aug 2004
    Walden, NY
    nice review... I was thinking this unit would be crappy b/c of the back plate missing thing, and the tons of usb cable, but if it turns out to be good, i might get this one. I also was thinking about the new one that will be out soon... This one: DWW-K301
    i'm still puzzeled how it should be... I have some time though... Also. I'm really eager to see how the TV works out... if it's not a good shot, i'll probably juust get a tv card inside the pc. So LMK
    cheers
    FLAC alti's Avatar
    NY
    would you say that it is anymore daylight readible then the 700? I saw the one at a meet and it was completely washed out. I was kinda hoping they might have used somesort of translusive coating on the screen to improve it. How does it compare to the screen you have up top (lilliput?)
    My Install
    Software:
    CFiG v1
    iGuidance Plugin for CF
    CarShell
    Working shell for a CarPC
    StopWatch
    StopWatch plugin remade for centrafuse RC1
    Minneapolis, MN
    The screen up top is actually a Xenarc w/o the brightness upgrade. So it's very hard to read in the daylight. This is definetly brighter than that Xenarc screen. I'm thinking of sending it in for the brightness upgrade, or just bying a new one.
    Which 700 are you talking about? The 750J 400 nits, which is as bright as any of the screens out on the market right now. I've got my eye on the backlight upgrade project going on, and hoping to maybe do that to both screens when it gets done.
    the 700M was hard to read text on in any condition IMO. This screen is much more clear, and when you adjust the "brightness" feature it doesn't just wash the LCD out, it actually boosts or lowers the backlight at the same time. Or at least appears to
  1. Replies: 4
    Last Post: 06-08-2005, 04:40 PM
  2. Replies: 1
    Last Post: 05-30-2005, 08:20 AM
  3. Any non-touch screen motorized monitors?
    By HaloGray in forum LCD/Display
    Last Post: 05-06-2005, 08:31 AM
  4. Replies: 10
    Last Post: 12-17-2004, 11:12 PM
  5. Full Screen
    By ericdee in forum LCD/Display
    Last Post: 12-02-2004, 05:57 PM
