Page 2 of 8 FirstFirst 12345678 LastLast
Results 11 to 20 of 72
Thread: AU Optronics Screen and VGA driver board (large images)
  1. #11
    The land of polar bears and nekkid blonds
    Quote Originally Posted by gorkRS232
    control is totally where it's at.
    Yep, and since power on/off is controllable it's bye bye to all the annoying "hibernating" "resuming to windows" texts.
    You can simply have it switch on and fade in once windows/your front end is loaded and then fade out and switch off when you turn the thing off.
    Sure, it'll be blank for a few seconds longer but I'd prefer that over "resuming from windows".
    Just need to get some connectors so I can start playing around with some software to control the thing
    /M
  2. #12
    Aug 2004
    Ann Arbor, MI
    where did you get it?
  3. #13
    Quote Originally Posted by Grey
    Local distributor over here in Sweden, you're probably better off calling Promate in the US asking them for a local source or if you could buy it from them.
    http://www.promate.com/contact_us/front.htm
    North America
    17870 Castleton Street, Suite 128 City of Industry, CA 91748 USA
    Tel: 626-965-4888
  4. #14
    Aug 2005
    Quote Originally Posted by Maximus
    Part numbers:
    JLPA070VW01-2 (TFT + touch integrated, ~ 320cd)
    A070VW01 (TFT panel , 400cd)
    JDBK070F2B1P (VGA controller kit, incl. cables, inverter and OSD panel)
    JDBK070G1A0P (AV/VGA kit, same as above)
    JDBK070T1A0P (LVDS-card for A070VW01)
    JTHS070F1A0 (7'' touch panel)
    JTHC084DUA1 (USB touch controller)
    The kit.
    So if I wanted to have the same setup you have I need
    JLPA070VW01-2; I assume it comes with the USB controller
    JDBK070F2B1P; or JDBK070G1A0P if I want A/V inputs?
    JTHC084DUA1; Needed if touch intergrated panel doesn't come with controller
    What is JDBK070T1A0P LVDS-card for A070VW01? I assume you only need that if you don't buy the integrated panel.
  5. #15
    Quote Originally Posted by Silentbob343
    Exactly !
    The "KIT" is only the VGA controller, inverter and OSD buttons, so you'll need the JTHC084DUA1 (USB Touch screen controller).
    The LVDS interface is used instead of the VGA controller if you'd wish to use LVDS but that's a straight LVDS interface without all the fancy features of the VGA controller, so in my opinion it's not worth it for the sake of LVDS.
    My order was:
    JLPA070VW01-2 7" TFT with touch
    JDBK070G1A0P 7,0"AV/VGA DVB Kit
    JTHC084DUA1 USB Ctrl RES 4W
  6. #16
    Managed to play around with it a bit more today and depending on what people mean by
    "exposed to direct sunlight" I think it handles it pretty well.
    I also managed to get 800X480. At least I think so, because the ODS never displays what mode it's in so you don't have any way to tell.
    I'll check into that a bit more.
    If you get the sunlight directly at the screen you cant see sh-t due to all the reflections,
    you could have all the backlight you want and I still think you wouldn't be able to see anything.
    The camera isn't able to capture the correct image, but you can make out some parts
    of the display, but it's not really usable.
    It would have been sweet to have the transflective version, but not even my Ipaq handles
    direct sunlight very well since it has an ever smoother surface than the AU screen does.
    Luckily sunlight almost never hit the display directly (unless you own a convertible)
    and if the sun hits the display at an angle it's a lot better. This is at ~45 degrees.
    The brightness is at about 80% so it has a bit more to give, but then the colors start to wash out so I like it better the way it is.
  7. #17
    Aug 2005
    the setup is a little pricey, but looks much better than lilliput or xenarc offerings
  8. #18
    The Xenarc is $375 @ mp3car store, I'd expect this kit would be around $350 in the US.
  9. #19
    is back. FKA Robert Wray
    Fiberoptic's Avatar
    Jul 1978
    Baltimore, MD
    Blog Entries
    143
    We (myself and ziplock) are in Taiwan now where they make this screen. We just had a good meeting where we talked about integrating this into future products with price drops. There will be more details soon.
  10. #20
    Way to go
    Have they showed you the transflective version ?
    A double DIN case with this screen pre-installed as a flip down unit would be sweet.
  1. FAQ: VGA vs. Composite (Video) Screens
    By cproaudio in forum The FAQ Emporium
    Last Post: 12-28-2007, 12:45 PM
  2. any feedback info. on Dynamix 7" VGA Touch Screen TFT ???
    By xtreamvette in forum LCD/Display
    Last Post: 04-22-2007, 04:19 PM
  3. 8" Xenarc VGA Touch Screen LCD - $325 shipped
    By digitalww in forum Classified Archive
    Last Post: 09-08-2005, 11:15 PM
