Tested again this morning.
Drove 35 min from home to work. Pulled in the parking lot and shut the car off. Walked around and double check the PSU's LED if blinking or not. Yup it was blinking. Hit the "User Switch" button, nada. Hit again couple times, and nada. Wait for a min then hit the power button, PC shutting down. Walked back to check the PSU. LED was blinking. Mobo's StandBy LED indicator was ON (meaning the PSU was on stand by). Waited a while, then PSU's LED and mobo's Standby LED was off (meaning PSU cut off power.)
Jeff 1 suggestion. If you can, make the 5V rail a little more powerfull. 15A maybe? Compare between 5V rail and 12V, the 5V rail is definitely weak. Regulating 5V is much easier (I think) than 12V right?There is plenty of power on 12V but not so much on 5V.
One of my AC PSU has 5A on 3.3V, 18A on 5V, and 4.5A on 12V. This PSU runs my setup perfect. And that is why I custom built my Sproggy as close to that output as possible.
greenman100 That is the reason I put a note there. However, the POL 5V and 12V were built into the Sproggy board. I called it POL because those 2 rails didn't joint together with the 20 pins ATX cable. I can't check those with the DSATX, unless I had to build one.
LinkBack URL
About LinkBacks
