Results 1 to 10 of 13
Thread: Pyle 7" Double Din LCD Review
    Sep 2005
    Hey guys, I just wanted to put a good word in for the Pyle in-dash double-din LCD tv/radio. I haven't seen many reviews of the product, so I thought I'd add my $.02
    When I first recieved the unit, I was very impressed. It looks great. Then, I opened the instructions- useless. But, luckily, every wire on the harness is individually tagged (a great plus). So, once I got the radio installed, I found my first major dissapointment.
    I turned on the radio (it has a 40x4 built in amp, another plus), expecting to see a cool tuner screen, seeing how it has RDS and a huge lcd to be creative. One word- BORING! The radio display is an absolute disgrace. If I weren't going to use mediacar with an FM tuner, I would get rid of this thing right away. The display for the radio takes so much away from the look of everything, including my Lincoln LS, which usually looks pretty good.
    Anyway, the sound is great. It has RCA outputs to go to my factory amp, and works well with my 8 speaker system.
    All in all, for $230, it was money well spent. I was going to buy a 7" lcd and then go from there, but I could never figure out how I was going to power all of the speakers and control them well. This is the perfect solution- a head unit, and an lcd screen, all for very little money.
    One other drawback- the unit has to be reset from time to time. Originally, this meant unplugging it and plugging it back in (major hassle). I don't know why it does this, but I bet it has something to do with costing only $230. But, I wired up a relay circuit with a switch in the glove box, so now it really doesnt matter at all.
    In the pic, you can see the boring radio screen. But, like I said, I'll be using media engine, which looks cool anyway. Oh yeah, thats primer- that dash install isn't complete yet.
    **Update: I've figured out why it needs to be reset. Well, basically, because its cheap. But, more specifically, something about Pyle head units can't handle the engine crank- most people probably never have a problem, but if you do, all you have to do is make sure that the unit isn't on right before you start your engine. I no longer need to use my reset switch.
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    um .. why does it have to be reset
    Variable Bitrate nadir_s's Avatar
    Oct 2002
    San Jose, CA
    pls post pics!
    [ 5-spd 1996 M A X i M A SE ]
    Tainted Love Cris's Avatar
    Romania
    What's a review without pics...?
    Elsewhere
    All text?
    How about the Wiki?
    Sep 2005
    I forgot my parents had a digital I could use. Pics are posted in the first post. The trim pieces have been primered, but still need more filling and sanding.
    Oh, and by the way, the SWI-X is amazing! It only took three wires (two of which were power and ground) to get my steering wheel controls to work!
    Sep 2005
    Quote Originally Posted by Sonicxtacy02
    I guess its a lower quality unit? It just freezes and won't turn on. I don't really know why it does that, but resetting it fixes it. It hasn't happened all week, so maybe it was just a couple of wires installed incorrectly on my part.
    Oct 2005
    so is this screen VGA or composite? I'm assuming VGA since you said you are planning to run MediaCar on it.
    Woodbridge, VA
    Blog Entries
    55
    its composite
  1. DIN and Double DIN Dimensions/Standards
    By kubark42 in forum General Hardware Discussion
    Last Post: 08-05-2009, 02:39 PM
  2. wtb: 7" double din touchscreen lcd
    By leijae in forum Classified Archive
    Last Post: 11-01-2005, 09:48 PM
  3. Need help selecting a 7" TFT LCD for <$200?
    By prospero in forum LCD/Display
    Last Post: 04-06-2004, 10:33 AM
  4. Can 7" touchscreen fit in double DIN opening?
    By RDaneel in forum LCD/Display
    Last Post: 02-26-2004, 02:53 PM
  5. LCD in DIN and Ford Mach 460
    By smashr2k in forum General Hardware Discussion
    Last Post: 09-21-2001, 10:33 PM
