Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: My new 7" motorized Touchscreen..
  1. #11
    Oct 2005
    Hou. TX
    Maybe it's cheaper because the screen is not as bright as the liliputs?
    Anyway, can the screen be set to open at different angles?
    Can the image be flipped upside down?
    I'd like to have the unit mounted upside down so that it comes out and flips down over my A/C controls rather than flip up and block the A/C vents.
    I see the VGA plugs straight into the rear, does that cause a depth problem or do you have to use some kind of 90* VGA plug to allow the unit to slide all the way into the dash.
    Does it stick out of the dash much?
  2. #12
    Maximum Bitrate yunusyu's Avatar
    May 2004
    Hollywood
    what about that TV function...try and plugin some antenna and tell us if it works
    thanks
    DICE Los Angeles
  3. #13
    Jan 2004
    St. Louis
    When you boot up...is there an OSD that's constantly reading the resolution. It's one of the things I'm hating about my Xenarc. Like someone posted in another thread, it takes away from the OEM look.
  4. #14
    Constant Bitrate PitchBlack98's Avatar
    Feb 2005
    Littleton, CO
    Quote Originally Posted by yunusyu
    thanks
    I have mine hooked up to recieve TV signals. It doesnt work that great. I can usually get a few channels while Im sitting still. I dont get much of anything why driving. Mostly just static with the occasional flicker of a picture. Im also using a powered antenna that sticks to the glass and I have it on my rear window.
    My review on the TV feature is its pretty much worthless unless you have a really good antenna.
    The end of the Internet offically begins here...
    www.broke-off.com
  5. #15
    Sep 2005
    Quote Originally Posted by tipastar
    No there is no OSD when booting that reads out the display resolution. The screen just waits for signal and then displays it.
  6. #16
    Dec 2005
    stupid question i know but..
    can you use your finger... or do you have to use a stylus to touch the screen?
  7. #17
    Variable Bitrate BIzFlawless's Avatar
    Oct 2005
    Tejas
    Since your a newb I guess its ok to ask such a stupid question , but yes YOU CAN USE YOUR FINGER!
  8. #18
    Dec 2005
    lol i figured you could.. but here's my thinking behind that question. i shoulda said it earlier. my friend has a tablet pc. and it only works with a stylus. so i had the assumption that you might have to always use the stylus pen to touch the screen cuz.... in the pictures on ebay... there's always a stylus in the graphics.. and well its ebay you have to make sure you read the ads very carefully.
    thanks for the quick response tho.
  9. #19
    Oct 2005
    Tejas
    Quote Originally Posted by BOIX
    Its koo, dont worry about it
  10. #20
    Newbie G20T's Avatar
    Mar 2006
    awsome unit, am currently trying to trade my in for a xenarc tsv screen, just cuz it sticks out from my dash board 12mm and am not happy with the other then the unit wicked
  1. $289 7" in dash motorized touchscreen LCD?
    By buurin in forum LCD/Display
    Last Post: 09-12-2006, 06:29 PM
  2. FS: Never Used 7" In-Dash Motorized VGA Touchscreen
    By CrazyModGSR in forum Classified Archive
    Last Post: 11-07-2005, 02:48 PM
  3. Geeks.com has a touchscreen motorized 7" LCD
    By danielsmith in forum LCD/Display
    Last Post: 08-29-2005, 05:11 PM
  4. Can u add touchscreen to Motorized 7"?
    By joejoe3 in forum LCD/Display
    Last Post: 09-30-2004, 01:25 PM
  5. 7" in-dash motorized touchscreen LCD w/ VGA inputs?
    By Salamander in forum LCD/Display
    Last Post: 08-22-2003, 11:44 AM
