Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 48
Thread: another M2-ATX review
  1. #21
    Constant Bitrate john94587's Avatar
    Sep 2005
    Bay Area, CA
    Good Review.
    Have you test how many watts will it go up to if you're playing a DVD??
    I'm guessing it will jump. LoL.
  2. #22
    Maximum Bitrate CavityCr33p's Avatar
    Jun 2003
    Arkansas
    I'm hoping my m2-atx coming in will be able to power mine....hrmm
    Athlon XP 1900+
    512mb DDR
    80gb 3.5" Hd
    Fullsize Slot load DVD-rom
    ATI rage agp card
    MSI Dualnet WiFi/Bluetooth card
    2.0 4 port PCI card
    Touchscreen usb and LCD power
    Ps2 mini Keyboard
    PS2/serial gps
    USB 2.0 4 port hub
    2000 Sunfire build 100%, or is it ever really 100%?
  3. #23
    Oct 2005
    Hou. TX
    For those that have 2+Ghz CPU's, have you considered down clocking it a little to 1500 or so? Drop the core voltage down some and bingo - comsumes less power, runs cooler and is still quick.
    Just a thought.
  4. #24
    Low Bitrate Goofus's Avatar
    Feb 2005
    Durkadurkastan, FL
    Here's my *****in Tigress.
  5. #25
    Sep 2005
    Bay Area, CA
    Quote Originally Posted by CavityCr33p
    Athlon XP 1900+
    512mb DDR
    80gb 3.5" Hd
    ATI rage agp card
    2.0 4 port PCI card
    Ps2 mini Keyboard
    PS2/serial gps
    USB 2.0 4 port hub
    Let me know how the progress goes. CavityCr33p
  6. #26
    Oct 2005
    Hou. TX
    Hey, I'm using an ATX PSU with the mobo connector jumped to get it to turn on and provide 12volts for me to test my M2.
    Now without a mobo to test, can I jumper the M2 mobo connector as well to get it to turn on? I plugged an LED into the LED jumper and plugged a fan into one of the molex connectors. It looks like the LED comes on, but the fan doesn't.
    Shouldn't the fan come on with the LED? Any other way to test this M2 without a mobo?
    I tried it with the mobo in the car, but it won't boot it up, so I want to see if the problem is in the M2 or my mobo.
  7. #27
    Jun 2003
    Arkansas
    You would probably need to jumper the M2, but Im not sure which pins...the same for the psu maybe?
  8. #28
    Oct 2005
    Hou. TX
    I tried that. It didn't seem to come on. I'm wondering if it HAS to have a mobo of some kind. I also tried not jumpering the M2 connector. The LED came on, but no fan.
    Jumpering consists of connecting the green mobo wire to one of the black ground wires next to it. Pretty easy.
  9. #29
    Variable Bitrate kamikaze2112's Avatar
    Feb 2005
    Barrie Ontario
    This may seem like a silly question, but if i want to run my monitor off the 12v rail, should I throw a fuse in there between the monitor and power supply? I'm also thinkin about running a usb hub as well, so i'm guessing the answer will be the same for both.
  10. #30
    Oct 2005
    Hou. TX
    If the monitor is pretty far away and there is a chance that the cable could get pinched, then add a fuse (3-5 amp fast blow) close to the PSU. I'm not really sure it's needed, though. Over the years I've shorted home PSU's by accident messing around with them and they usually shut off instantly.
  1. Powerin the LCD with the M2 atx
    By luckyno in forum LCD/Display
    Last Post: 01-20-2006, 02:14 PM
  2. Wtb: M2 Atx
    By EsKALad in forum Classified Archive
    Last Post: 01-03-2006, 09:59 AM
  3. morex 80wpsu and reg ATX cable dilema!!
    By surfy in forum Power Supplies
    Last Post: 08-16-2005, 09:06 PM
  4. Micro ATX or ATX
    By custardbomb in forum Power Supplies
    Last Post: 08-14-2005, 07:48 AM
  5. ATX and AT motherboard
    By Beavis in forum Power Supplies
    Last Post: 05-10-2001, 03:22 PM
