Results 1 to 10 of 18
Thread: Thanatos' M2-ATX review
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    So I finally fixed the internet prob (kind of) and I was able to upload the PICs and make this review.
    Firts the specs of the testing SYS:
    Processor: Pentium 2.4 GHZ/1M/533
    Motherboard:Asrock P4i45GV
    Memory:512 MB DDR 400 PC3200
    Hard drive:Seagate 3.5" 80 GB 7200 RPM
    DVD drive:Sansung 16X (full size)
    PCI cards:3com network card
    USB devices:Linksys WUSB54G wireless usb adapter
    PSU to provide 12V to the M2-ATX:Codegen 400W MAX
    Firts I did was to isolate the unit so I won't damage any part of the testing hardware or PSU. I used standoffs and a pice of plexi:
    Then I soldered 3 pins of a male molex that I had laying around, so I don't have to cut the cables of a good PSU (just insert them in to the female molex:
    Also I have to made my own switch wire cus the factory one is really short:
    Then I pluged the M2-ATX to the Mobo and start teting the futures of the unit. I also connected the power led and the optinal manual switch, they all work fine.
    This is a couple of pics of the unit mounted in to the PC case (I hold it down with a clamp):
    The unit power up the system and it did all the shudown process without any problem. I ran a DVD move and leave the PC running all night playing MP3s and the next morning everything still working.
    Now the little problems I encountered (besides the switching cable of course!):
    The input cables connectors are too close to each other, making the disconnecting procedure to me super hard:
    Also this is no a big deal but when testing the different offdelay I discovered that mode 6 (30 min) is off for about 2 min and 30 secs, and mode 7 (3 hours) is off about 3 min 12 secs (and yes I did test it with a watch in hand )
    So this is it, I had more pics but something weird is happening with photo bucket cus when trying to upload more pics they were only have of it!
    I hope this helps andrewB with his product, and many more users that been wodering about the M2-ATX.
    Thanatos.
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
    Oct 2005
    Hou. TX
    Quote Originally Posted by thanatos106
    For a moment there I thought you said mode 6 only lasted 2m and 30secs and then turned off. But you mean it (30 minutes) was close but not quite accurate. So it was like 27.5 or 32.5 minutes, right? Just want to make this clear.
    Nov 2004
    It was 32.5 min instead of 30 min for the PC to power off.
    Thanatos.
    Nissan Aux-in MOD
    Raw Wave tbird2340's Avatar
    Oct 2003
    Poland, OH
    So to power it w/ your ATX PSU you just connected the IGN (white) and CONSTANT (red) to YELLOW (12V) wires of your PSU and the GROUND (black) to a BLACK wire of the PSU..
    Then what did you do to get it to boot up?
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
    Nov 2004
    This is the trick:
    And the IGN (white) I pluged and unpluged to another molex yellow (12V) cable (cus I used male molex pins, I just have to pull it to simulate that it switch off *take alook to the pic below*)
    And the white.
    Thanatos.
    Nissan Aux-in MOD
    Oct 2003
    Poland, OH
    Weird.. I do the same and my mobo doesn't power on. I do have the lan light blinking but it won't power on?
    Variable Bitrate checksum's Avatar
    Feb 2006
    Columbia/MD
    Thanks for the review.
    Did you do any power calculation?
    How much power would you say that the P4 2.4GHZ draws?
    Did the unit get really hot when you left it on the whole night? I am trying to see if it will require a fan or not.
    Is that all the peripherals you plan to power with your M2ATX?
    Where did you purchase it?
    2005 Nissan Altima - Completed 2007
    2010 Nissan Altima - Coming Soon...
    Oct 2005
    Hou. TX
    Quote Originally Posted by checksum
    Max power consumption varies depending on which core you have. Intel lists "typical power consumption", unlike AMD which lists max. Still, you have to read between the lines for certain processors.
    Here are the 2 Intels:
    Intel Pentium 4 A 2400 MHz Prescott (89 Watts)
    Intel Pentium 4 C 2400 MHz Northwood (66.2 Watts)
    So you have to increase the wattage a little to get the max. Figure 100w for the Prescott and 75-80w for the Northwood. Now under normal CarPC usage your not going to be pushing the CPU very hard so it will be running cooler.
    The new 90nm AMD Sempron, for comparison, maxes out at about 30w. This is the 3000+ model.
    I know the AMD's pull their CPU voltage from the 12v rail, but I think the Intels get their voltage from the 5v rail.
    Low Bitrate SuprchargdMazda's Avatar
    Mar 2006
    Quote Originally Posted by JasonWW
    I'm in the search for a processor right now to run on a M2, saw your post and went to newegg.com and looked up 90nm process type Sempron series, and the only cpu that came up was the Sempron 3100+ : http://www.newegg.com/Product/Produc...82E16819104220
    Is this the only one that uses up about 30W, cuz I know according to http://users.erols.com/chare/elec.htm Semprons use up ~65W?
    Also, to the original poster, why are you hooking up your DC-DC power supply to a regular power supply used in a computer? I thought the purpose of going DC-DC was to avoid regular psu's and inverters?? I don't understand the connections going on here....
    Oct 2003
    Poland, OH
    Quote Originally Posted by SuprchargdMazda
    My M2 runs everything in my signature.. I think the OP was powering the M2 via the house PSU to test and write his review w/out instaling it in his car.
  1. Powerin the LCD with the M2 atx
    By luckyno in forum LCD/Display
    Last Post: 01-20-2006, 01:14 PM
  2. Wtb: M2 Atx
    By EsKALad in forum Classified Archive
    Last Post: 01-03-2006, 08:59 AM
  3. morex 80wpsu and reg ATX cable dilema!!
    By surfy in forum Power Supplies
    Last Post: 08-16-2005, 08:06 PM
  4. Micro ATX or ATX
    By custardbomb in forum Power Supplies
    Last Post: 08-14-2005, 06:48 AM
  5. ATX and AT motherboard
    By Beavis in forum Power Supplies
    Last Post: 05-10-2001, 02:22 PM
