Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Hardware Review: Provision 8" 16:9 VGA Touchscreen
  1. #11
    Registered User cliffloehr's Avatar
    May 2006
    Decatur, AL
    I just so happened to have mine is pieces while I redo the car's bezel.
    Display area:
    Diagonal: 8.044"
    LCD Panel (Outside):
    Height= 4.729"
    Width= 7.447"
    Thickness=0.416"
    Casing (Outside):
    Height= 5.103"
    Width= 7.623"
    Thickness=0.980"
    The correct native resolution is 800x640 but do to limitations of the VIA Mini-ITX motherboards I run mine in 800x600 and it looks good enough. It also handles 1024x768 just fine but stuff is too tinny to see.
  2. #12
    Jan 2003
    Quote Originally Posted by cliffloehr View Post
    Isn't there a hack/mod on the VIA video drivers to get it to work with 800x480?
  3. #13
    May 2006
    Decatur, AL
    try this...
    Finally somebody with the bios/driver
    Be sure to reed through the whole post... is covers the MII and M10000
  4. #14
    Variable Bitrate redls1bird's Avatar
    Feb 2006
    what kind of switch/button/anything does this screen use to turn on? is it a momentary switch? im sure we can come up with something to turn it on and off automatically. with all the good reviews, im going down to measure the room in my car to see if i can make it fit!
    Car Pc progress meter:
    [-----------------85%---] Looking good! Total spent : $740, Thats including two touch screens!!!
    "The car is the closest we will ever come to creating something that is truly alive" -Sir William Lyons
    My worklog
  5. #15
    Constant Bitrate anik321's Avatar
    Nov 2004
    lightman,
    I know this is asking a lot (since it already doesnt even have auto-on feature)
    but does it by any chance switch from one input to another (say VGA to RCA) if a video signal appears on the RCA input ? (for reverse camera purposes)
    thanks!
    99' V6 Solara SE.
    '05 CBR600RR
    Baltimore MD.
    Shuttle XPC| 512MB | 120GB 3.5" Seagate
    Opus 150W PS | Rikaline 6010 GPS
    7" Lilliput 619 | Centrafuse | IGuidance 3
  6. #16
    May 2006
    Decatur, AL
    I was especially disappointed in that you have to hold it in for 3 seconds to even turn it off. I ended up attaching it to the ignition wire so it would turn off automatically. That helped a lot!
  7. #17
    Apr 2007
    Provision problem
    I bought a used Provision PRTV 800 8" lcd touchscreen. Both RCA video inputs work but there was a broken wire on the VGA plug. I repaired it but when I went to plug it in I realized that the plug on the end of the VGA cable was a 7 pin and the female plug on the board was a 9 pin. Is this similat to yours? I have no documentation for this monitor and calling Provision in Houston for support was a total farce. Can anyone help me?
  8. #18
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    You will need the extension cable or something like it... read post #4.
    TruckinMP3
    Read the FAQ!
  9. #19
    Mar 2007
    Germantown, MD
    I got the same screen, i need to work on the circuit board to make it to turn on whenever it receives +12v, anybody knows ?
  10. #20
    Jun 2009
    So how easy is this screen to fit into a into a double din hole. my Tiguan has a nice size opening and want to get the biggest screen that will fit for easy viewing.
  1. FS/FT 8" touchscreen monitor with video inputs
    By nocturnal669 in forum Classified Archive
    Last Post: 01-18-2007, 08:12 AM
  2. Replies: 1
    Last Post: 07-20-2006, 10:52 PM
  3. 8" touchscreen Lcd input question?
    By kitt350 in forum LCD/Display
    Last Post: 04-02-2006, 04:10 PM
  4. FS: DIGITALWW 7VGA touchscreen vga lcd
    By almanc in forum Classified Archive
    Last Post: 12-15-2004, 06:44 PM
  5. Trade: 8" VGA USB Touchscreen *for* 10.4" VGA touchscreen.
    By Euclid in forum Classified Archive
    Last Post: 02-10-2003, 11:43 PM
