Results 11 to 20 of 23
Thread: EnGenius EUB-362 Wireless Wifi USB Adapter Review
  1. #11
    Aug 2005
    Plano/College Station, TX
    I've got this same adapter and it gets great reception. I'm having trouble with it blocking my shut-down procedures though? Whenever it's plugged in my computer takes forEVER to shut down, but if i unplug it while it's shutting down, it will shut down almost right away. Any ideas LURCH?
  2. #12
    Mar 2006
    Blog Entries
    1
    My shutdown doesn't take any longer with the EnGenius.
  3. #13
    Aug 2005
    Well the shutdown works alright now... don't know what happened with that. I'm just having a HELL of a time finding and keeping a connection for any period of time. Half the time it won't find a network at all, the other half it finds a network and gets great signal, but won't transfer a damn byte of information. I've reinstalled the drivers twice and I'm starting to get fed up with it.
  4. #14
    Mar 2006
    Blog Entries
    1
    The problems you're describing sounds like my Linksys PCI card. I'm really happy with my EnGenius though.
  5. #15
    Constant Bitrate agniusm's Avatar
    Oct 2006
    Lisburn
    This adapter is indeed good. 200mW. Im using them on dish reflector antennas with biquad feed. remooving casing, soldering LMR400 direct into PCB from biquadfeed, weatherproof enclosure, works like thunder
  6. #16
    Jun 2005
    quick questions:
    Does it require external power (110V power adapter) or just the USB power?
    would the connection resume after hiberation?
  7. #17
    Oct 2006
    Lisburn
    Powered from usb, connection resumes, at least with mine, thou its not like resumes, connects again if u set it up right
  8. #18
    Jun 2005
    Quote Originally Posted by agniusm View Post
    thanks
  9. #19
    Apr 2005
    Queens, New York
    mine does not allow my PC to hibernate! It only happens once in a while!
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
  10. #20
    Jun 2005
    Quote Originally Posted by Cheekz185 View Post
    what OS are you using?
  1. Replies: 23
    Last Post: 09-26-2007, 09:43 PM
  2. What kind of USB Wifi adapter do you use?
    By [H]Bugster in forum General Hardware Discussion
    Last Post: 01-23-2004, 11:30 AM
  3. Wake on USB mouse or wireless adapter
    By Alric in forum General Hardware Discussion
    Last Post: 01-22-2004, 10:44 AM
  4. Compaq 11mbps wireless usb adapter
    By jol in forum General Hardware Discussion
    Last Post: 03-03-2003, 01:19 PM
