Page 1 of 7 1234567 LastLast
Results 1 to 10 of 69
Thread: Hardware Review: Auzentech X-Meridian 7.1
    _
    Mar 2004
    Little Elm, Texas
    I'm going to style this after durwoods review of the Audiotrek. It just made things easier!
    What it is/does: High Performance 8 Channel Audiophile PCI soundcard
    Reviewed by: RedGTiVR6
    Manufacturer : Auzentech
    Model: Auzen X-Meridian 7.1
    Specs:
    • The C-Media Oxygen HD CMI8788 Audio Processor is the heart of the AUZEN X-MERIDIAN 7.1.
    • 4 pcs 24-bit/192kHz AK4396VF (120dB-part spec.) DACs for 7.1channel output. (24-bit/192kHz in 7.1channel playback)
    • 1 pc 24-bit/192kHz AK5385VF(114dB-part spec.) ADC input (24-bit/192kHz recording)
    • 1 pc CMI9780 AC'97 2.3 CODEC for AUX input, CD input, MIC input (16bit/48kHz playback/recording)
    • Integrated up to 192k/24-bit S/PDIF transmitter for 44.1kHz,48kHz, 96kHz, 192kHz SPDIF output.
    • Supports onboard high grade special COAX+OPTIC combo type transmitter module for up to 192kHz SPDIF out.
    • Integrated up to 192k/24-bit S/PDIF receiver for 44.1kHz,48kHz, 96kHz, 192kHz SPDIF input.
    • Supports onboard high grade special COAX+OPTIC combo type receiver module for up to 192kHz SPDIF input.
    • Standard 10PIN Front Panel Audio supports connectivity for stereo audio output and a microphone input from most new chassis. (All 7.1channel analog output muted by jack connection sense of front panel headphone out / Dual MIC input available by back panel mic input and front panel mic input)
    • DTS® Interactive - A real-time 5.1 channel encoder.
    • DTS® Neo:PC - An upmix matrix technology.
    • Dolby® Digital Live (DDL) - A real-time 5.1 channel encoding.
    • Dolby® ProLogic IIx surround processor spreading stereo audio into 7.1 channel surround sound.
    • Dolby® Headphone technology, conveying 5.1 surround and 3D gaming audio over stereo headphones.
    • Dolby® Virtual Speaker solution, bringing amazing virtual surround sound fields via general two speakers.
    • C-Media FlexBass™ - LFE channel crossover frequency setable from range 50 to 250Hz in Small speaker mode and Small/Large speaker selectable.
    • C-Media Magic Voice™, popular feature for disguising your tone in online chatting.
    • C-Media Xear 3D™ 7.1 Virtual Speaker Shifter technology.
    • C-Media’s unique Karaoke functions: Microphone Echo, Key-shifting.
    • Individual 10-band EQ for each channel,.27 global reverberation environments.
    • Supports most industrial standards of 3D sound for PC gaming, including EAX™ 1.0 & 2.0, A3D™ 1.0, and DirectSound™.
    • Swappable DIP type OPAMP controlled preamp out circuit (4pcs output control OPAMP IC with DIY socket)
    • Surface mount type OPAMP controlled preamp input circuit (2pcs input control OPAMP for ADC and 1pc MIC input gain control)
    • 5Vrms (Differential DAC output with gain adjustment / approximately full swing from +/- 8V dual power supply)
    • Proper OPAMP control circuit (large capacity 1A +8V, -8V, dual power supply circuit) for high quality audio quality, prevent audio distortion at high volume level.
    • Upgrade Extension available (Extra 6.35mm MIC / Extra Digital I/O sold separately)
    • Supported operating systems: Microsoft Windows® 98SE / ME / 2000 Service Pack 3(SP3) / XP Service Pack 1(SP1) / Server 2003 SP1/ XP Media Center Edition 2005 (MCE) / XP x64 Edition.
    Price: $199
    Rating: Untested, a 9/10.
    I'd like to see the following:
    RCA style jacks - but to get enough RCA jacks out on a card like this, it would have to have more than one normal sized back plate.
    Manufacturer website: www.auzentech.com
    Purchased at: http://www.newegg.com/
    Pros:
    • High Quality Components
    • User replaceable opamps
    • Digital Optical IN and Out
    • 5Vrms outputs (tested at both 60Hz and 1kHz to read 4.74v)
    Cons:
    • As mentioned above, I would like to have seen female RCA jacks.
    • There's almost too much stuff you can do with this card. For some that might be a pro. For my application, I'm marking it as a con because I want to be sure that all processing is turned off on the card so that I can do it all via the software that I choose.
    • I would like to see more analog outputs, but again, I'm sure that for most people this card will have plenty of outputs.
    • I don't believe there is any 'directwire' program like other cards have. However, this should be controllable via some outboard software programs.
    Jan Bennett
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    I am a little confused. It does have something similar to "directwire" or is that ASIO part of the card? Also, does it really have ASIO drivers? I was told no, but their website says yes. I guess I'll wait until you give a full test run.
    _
    Mar 2004
    Little Elm, Texas
    I have no idea, right now I've got a lot going on...lol
    where did you see the info about direct wire?
    Jan Bennett
    Sep 2006
    Oh ok. I think if you just cut and pasted from my review it must have accidently carried over from the Prodigy Review. Look at your "pros" list.
    I know the feeling. With Christmas, trying to buy a house in the next few months, catching up on 3 seasons worth of 24, trying to get together with friends, craziness at work and then when I have free time, test software and hardware for my new carputer setup.
    _
    Mar 2004
    Little Elm, Texas
    thanks - updated....
    new job is making things pretty hectic around here...lol
    Jan Bennett
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by durwood View Post
    Once I loaded Allocator, I found that the card shows up under ASIO, see attached:
    Jan Bennett
    _
    Mar 2004
    Little Elm, Texas
    Also, just thought I would update this thread with some info for those interested in hacking...
    Jan Bennett
    _
    Mar 2004
    Little Elm, Texas
    And a few more:
    Jan Bennett
    Dec 2006
    This is nice hack .... can you provide more details about the (I believe it is) rca jack you are about to install ??
    _
    Mar 2004
    Little Elm, Texas
    New CarPC - this one for tuning
    that should help you out some.
    Jan Bennett
  1. Hardware Review: Provision 8" 16:9 VGA Touchscreen
    By lightman in forum The Review Palace
    Last Post: 06-15-2009, 09:02 AM
  2. Replies: 14
    Last Post: 04-13-2007, 02:23 PM
  3. Hardware Review: SB Audigy2 NX External USB Sound Card
    By hari-bhari in forum The Review Palace
    Last Post: 12-13-2006, 04:55 PM
  4. Hardware Review: Overdue M2ATX review
    By elstev0 in forum The Review Palace
    Last Post: 09-03-2006, 10:10 AM
