Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Hardware Review: ElmScan 5 ODB-II scanner with StreetDeck
  1. #11
    Dec 2004
    Miami, FL
    While we're at it, how does the install go with the ElmScan? I've been running Streetdeck for a while, and just ordered the ElmScan from the mp3car store. What software does it come with? I dont see much by the way of documentation other than this thread.
    Do I just plug it in and Streetdeck recognizes the device?
    IF you're logging data, do you just leave this thing plugged into your obd-ii port at all times? Can it handle car & carputer startup/shutdown if plugged in at all times?
    A car without turbo is a car with perpetual lag.
    My Ride
    My New Page
  2. #12
    _
    Mar 2004
    Little Elm, Texas
    Download the driver and install it.
    You can also get the ElmScan software for free from the ElmScan web site.
    Jan Bennett
  3. #13
    Dec 2004
    Miami, FL
    Red,
    How did you get the hardware working with Streetdeck? I plugged it in and the Scantool.net software can get information, but Streetdeck keeps throwing me errors. It shows "Connecting..." at the top of the screen for 10-15 second or so, then says it cannot connect.
    I also notice that on the Elmscan itself, the power light is red when all plugged in. Once I hit connect, that light goes green, but that's it. When using scantool.net, the power light goes green but then the tx and rx lights start flickering.
    Edit: http://www.mp3car.com/vbulletin/stre...treetdeck.html
    Looks like I'm not the only one.
    My Ride
    My New Page
  4. #14
    Dec 2004
    Miami, FL
    *** READ ME BEFORE BUYING THIS DEVICE ***
    http://www.mp3car.com/vbulletin/tracker.php?itemid=76
    My Ride
    My New Page
  5. #15
    Low Bitrate wonderworm's Avatar
    Jan 2004
    I wish to use an ODBII reader with my carputer and software to double as a scanguage so I can read real-time MPG values while driving.
    Can this be accomplished with this device and the proper software?
  6. #16
    _
    Mar 2004
    Little Elm, Texas
    I would research the capabilities of the OBD-II software first. This is a review of how the software runs from within a front end. There is an entire sub-forum dedicated to OBD-II scanners and their software too. It would be a good place to start reading up on OBD-II, it's functionality, and it's implementations.
    Jan Bennett
  7. #17
    May 2008
    Quote Originally Posted by wonderworm View Post
    The hardware is capable of reading the information needed to calculate MPG but it's up to the software to be able to do the calculations.
  1. ODB II and GM DIC
    By cw95403 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 11-22-2008, 02:40 AM
  2. Hardware Review: ShuttleXpress
    By Genesisfactor in forum The Review Palace
    Last Post: 10-20-2006, 08:44 PM
  3. review of elmscan interface
    By RogerWilco in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2004, 05:16 PM
  4. Newbie question about ODB I and II
    By Nokia6600 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-24-2004, 11:59 PM
  5. does my car have odb ii
    By essentialcruise in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 12-23-2003, 09:07 PM
