Running .1331 with update 2...
BTW, I'm running the 2.1.0.9 (or is it 2.1.0.8?) plugin. I tried the original release, and it did the same thing...
This is a clean install of XP...had the exact same issue with my previous Vista install. So it's not an OS issue, like I previously thought.
I'm guessing it's because maybe 1 of the sensors isn't programmed? We'll know for sure when the new spare sensor arrives and I get it installed...
Did you do the dll update? Wolfgang has it posted in the thread a post or two below the OP. You have to cut and paste the new dll/language folder into the tpms folder in your CF directory. I don't think having one sensor programmed would cause this issue, it should not make a difference how many sensors are programmed in.
Okay...downloading now...
I never guessed to look back on page 1 for updates. I figured they would of came in order, or posted in the download section :)
Thanks Alok...
I'll re-test with the 3 sensors I have running now. I got the new sensor in the mail last week...thanks again.
It'll have to wait til I can afford tires for me to install it!
Hi Alok
Well finally the system is UP n working as i have got a new screen but am not able to get all the sensors to LEARN....
i could only manage to get 2 to learn....So did try to do a Master reset... Still no luck
can you pls help as how do i go about it
Capt Vikas Uberoi
Hello Vicky,
The problem you are having is due to the sensors going into storage mode since they have have been in little or no pressure for quite some time. If you raise the PSI over 15 and then back down below 5 this should 'wake' the sensors. Then proceed with the learning procedure as normal. If you still have issues please let me know and we can try to figure out what is going on.
