Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Centrafuse, TPMS 2.1.0.9 and Vista
  1. #11
    FLAC WuNgUn's Avatar
    Sep 2007
    Running .1331 with update 2...
    BTW, I'm running the 2.1.0.9 (or is it 2.1.0.8?) plugin. I tried the original release, and it did the same thing...
    This is a clean install of XP...had the exact same issue with my previous Vista install. So it's not an OS issue, like I previously thought.
    I'm guessing it's because maybe 1 of the sensors isn't programmed? We'll know for sure when the new spare sensor arrives and I get it installed...
  2. #12
    Lok
    Lok is offline
    VENDOR - Portal Media Lok's Avatar
    Feb 2008
    Did you do the dll update? Wolfgang has it posted in the thread a post or two below the OP. You have to cut and paste the new dll/language folder into the tpms folder in your CF directory. I don't think having one sensor programmed would cause this issue, it should not make a difference how many sensors are programmed in.
  3. #13
    Sep 2007
    Okay...downloading now...
    I never guessed to look back on page 1 for updates. I figured they would of came in order, or posted in the download section
    Thanks Alok...
    I'll re-test with the 3 sensors I have running now. I got the new sensor in the mail last week...thanks again.
    It'll have to wait til I can afford tires for me to install it!
  4. #14
    Maximum Bitrate vicky_obee's Avatar
    Dec 2003
    Hi Alok
    Well finally the system is UP n working as i have got a new screen but am not able to get all the sensors to LEARN....
    i could only manage to get 2 to learn....So did try to do a Master reset... Still no luck
    can you pls help as how do i go about it
    Capt Vikas Uberoi
    Commell LV-677 DC 6 x 6" Mother Board
    2.6 GHz; 1 Gb Ram
    120 Gb Laptop HD
    7" InDash Xenarc MTD - X7000 Screen
    Gyration Mouse ; GPS Mouse ; ELM Scan ; TPMS
    Parrot MK 6000 & iPhone
    Re done the carputer...Into the Glove Box !!
  5. #15
    Lok
    Lok is offline
    Feb 2008
    Hello Vicky,
    The problem you are having is due to the sensors going into storage mode since they have have been in little or no pressure for quite some time. If you raise the PSI over 15 and then back down below 5 this should 'wake' the sensors. Then proceed with the learning procedure as normal. If you still have issues please let me know and we can try to figure out what is going on.
  1. Centrafuse 2.0 Final
    By Jan_RedGTiVR6 in forum Centrafuse
    Last Post: 08-17-2008, 12:35 PM
  2. Centrafuse 2.0 RC4
    By veetid in forum Centrafuse
    Last Post: 06-10-2008, 08:31 PM
  3. Centrafuse 2.0 RC3
    By smeesseman in forum Centrafuse
    Last Post: 05-21-2008, 09:29 PM
  4. Centrafuse 2.0 RC2
    By Ogold007 in forum Centrafuse
    Last Post: 05-21-2008, 02:59 PM
  5. Centrafuse Vista Compatibility?
    By bns2000 in forum Centrafuse
    Last Post: 09-08-2007, 07:41 AM
