Centrafuse, TPMS 2.1.0.9 and Vista
...don't get along well together...lol This is Vista, not SP1, although I did install the SP1 upgrade, and issues with CF were worse in my case.
The plugin installs fine, and works fine, reading the data properly.
But after some time, CF becomes unresponsive. Not technically 'unresponsive' (as in the task manager), but inputs to volume, etc don't do anything...right away. After some seconds pass (30 or 40), the input is registered and executed however. CF continues functioning as far as playing media/NAV/etc...
When CF is restarted, more often than not, it restarts in this non-responsive state immediately...until the plugin is removed.
After I install the plugin, I configure the wheel assignments and change BAR to PSI and set my pressure ranges...prior to changing these settings, CF seems fine, however it might be a coinsidence, as it only take a minute to change.
I will however, retest without any changes to the options, in case the issue is caused by maybe the PSI conversion or the tire reassignments, just to be sure...
I'll report back later today...
Is there a more recent CF plugin available for testing?
