Results 1 to 10 of 15
Thread: Centrafuse, TPMS 2.1.0.9 and Vista
    FLAC WuNgUn's Avatar
    Sep 2007
    ...don't get along well together...lol This is Vista, not SP1, although I did install the SP1 upgrade, and issues with CF were worse in my case.
    The plugin installs fine, and works fine, reading the data properly.
    But after some time, CF becomes unresponsive. Not technically 'unresponsive' (as in the task manager), but inputs to volume, etc don't do anything...right away. After some seconds pass (30 or 40), the input is registered and executed however. CF continues functioning as far as playing media/NAV/etc...
    When CF is restarted, more often than not, it restarts in this non-responsive state immediately...until the plugin is removed.
    After I install the plugin, I configure the wheel assignments and change BAR to PSI and set my pressure ranges...prior to changing these settings, CF seems fine, however it might be a coinsidence, as it only take a minute to change.
    I will however, retest without any changes to the options, in case the issue is caused by maybe the PSI conversion or the tire reassignments, just to be sure...
    I'll report back later today...
    Is there a more recent CF plugin available for testing?
    Sep 2007
    Here is the last log file from the TPMS....I see errors, but that's all I know. Anyone care to have a look?
    Thanks...
    40:59:30> Click_Action(): CurrValue=2
    41:04:70> Click_Action(): CurrValue=1
    41:04:90> Click_Action(): CurrValue=2
    41:05:10> Click_Action(): CurrValue=3
    41:05:43> Click_Action(): CurrValue=4
    12:56:06> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    at System.IO.FileStream.EndWrite(IAsyncResult asyncResult)
    at System.IO.FileStream.FlushWrite(Boolean calledFromFinalizer)
    at System.IO.FileStream.Dispose(Boolean disposing)
    at System.IO.Stream.Close()
    at tpms.HIDDevice.Dispose(Boolean bDisposing)
    at tpms.HIDDevice.Dispose()
    at tpms.HIDDevice.Write(OutputReport oOutRep)
    at tpms.TpmsDevice.WriteReport(TpmsOutputReport outputReport)
    at tpms.tpms.GetDataFromDevice()(): A device attached to the system is not functioning.<CR><LF>
    54:33:78> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    54:34:78> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    54:56:33> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    at System.IO.FileStream.BeginWriteCore(Byte[] bytes, Int32 offset, Int32 numBytes, AsyncCallback userCallback, Object stateObject)
    at tpms.tpms.GetDataFromDevice()(): Unable to find the specified file.
    56:03:94> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    19:14:80> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    19:17:57> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    19:25:63> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    19:31:52> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    19:39:30> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    19:55:39> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    20:02:64> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    20:10:06> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    22:55:40> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    23:17:72> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    23:55:61> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    04:50:83> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    04:51:88> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    05:17:66> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    05:44:16> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    06:44:96> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    08:28:66> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    09:28:82> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    14:30:37> Click_Action(): CurrValue=2
    14:33:46> Click_Action(): CurrValue=1
    14:33:65> Click_Action(): CurrValue=2
    14:33:84> Click_Action(): CurrValue=3
    14:34:04> Click_Action(): CurrValue=4
    24:19:08> Click_Action(): CurrValue=2
    24:20:40> Click_Action(): CurrValue=1
    24:20:58> Click_Action(): CurrValue=2
    24:20:75> Click_Action(): CurrValue=3
    24:20:93> Click_Action(): CurrValue=4
    17:25:23> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    18:24:93> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    19:32:73> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    19:52:79> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    56:26:95> loadSettings(): START
    56:26:96> loadSettings(): END
    56:26:97> LoadValues(): START
    56:26:97> CF_localskinsetup(): START
    56:27:07> CF_localskinsetup(): END
    56:27:07> CF_pluginInit(): END
    56:32:67> TPMS_Loaded(): START
    56:32:68> TPMS_Loaded(): END
    56:33:72> GetDataFromDevice(): START
    56:34:60> GetDataFromDevice(): END
    56:35:64> GetDataFromDevice(): START
    56:36:17> GetDataFromDevice(): END
    56:37:19> GetDataFromDevice(): START
    56:37:74> GetDataFromDevice(): END
    56:38:73> GetDataFromDevice(): START
    56:39:27> GetDataFromDevice(): END
    56:40:27> GetDataFromDevice(): START
    56:40:89> GetDataFromDevice(): END
    56:41:04> Btn_Click(): START
    56:41:04> Btn_Click(): EMD
    56:41:88> GetDataFromDevice(): START
    56:42:39> GetDataFromDevice(): END
    56:43:39> GetDataFromDevice(): START
    56:43:90> GetDataFromDevice(): END
    56:44:91> GetDataFromDevice(): START
    56:45:43> GetDataFromDevice(): END
    56:46:65> GetDataFromDevice(): START
    56:46:97> GetDataFromDevice(): END
    56:47:97> GetDataFromDevice(): START
    56:48:49> GetDataFromDevice(): END
    56:49:50> GetDataFromDevice(): START
    56:49:92> GetDataFromDevice(): END
    56:50:95> GetDataFromDevice(): START
    56:51:46> GetDataFromDevice(): END
    56:52:47> GetDataFromDevice(): START
    56:52:99> GetDataFromDevice(): END
    56:54:05> GetDataFromDevice(): START
    56:54:57> GetDataFromDevice(): END
    56:55:26> CF_pluginInit(): END
    56:55:27> CF_localskinsetup(): START
    56:55:41> loadSettings(): START
    56:55:41> loadSettings(): END
    56:55:41> CF_localskinsetup(): END
    56:55:41> CF_pluginInit(): END
    56:55:66> GetDataFromDevice(): START
    56:56:18> GetDataFromDevice(): END
    56:57:17> GetDataFromDevice(): START
    56:57:69> GetDataFromDevice(): END
    56:58:69> GetDataFromDevice(): START
    56:59:21> GetDataFromDevice(): END
    57:00:20> GetDataFromDevice(): START
    57:00:72> GetDataFromDevice(): END
    57:01:72> GetDataFromDevice(): START
    57:02:23> GetDataFromDevice(): END
    57:03:25> GetDataFromDevice(): START
    57:03:77> GetDataFromDevice(): END
    57:04:72> Setup_Click(): START
    57:04:72> Setup_Click(): END
    57:04:79> GetDataFromDevice(): START
    57:05:31> GetDataFromDevice(): END
    57:06:31> GetDataFromDevice(): START
    57:06:83> GetDataFromDevice(): END
    57:07:82> GetDataFromDevice(): START
    57:08:34> GetDataFromDevice(): END
    57:08:35> Setup_Click(): START
    57:08:35> CF_localskinsetup(): START
    57:08:56> loadSettings(): START
    57:08:57> loadSettings(): END
    57:08:57> CF_localskinsetup(): END
    57:08:57> Setup_Click(): END
    57:09:35> GetDataFromDevice(): START
    57:09:87> GetDataFromDevice(): END
    57:10:86> GetDataFromDevice(): START
    57:11:37> GetDataFromDevice(): END
    57:12:25> Setup_Click(): START
    57:12:25> Setup_Click(): END
    57:12:45> GetDataFromDevice(): START
    57:12:87> GetDataFromDevice(): END
    57:13:86> GetDataFromDevice(): START
    57:14:37> GetDataFromDevice(): END
    57:15:37> GetDataFromDevice(): START
    57:15:89> GetDataFromDevice(): END
    57:15:90> Setup_Click(): START
    57:15:90> GetNewPressure(): START
    57:16:90> GetDataFromDevice(): START
    57:17:42> GetDataFromDevice(): END
    57:18:42> GetDataFromDevice(): START
    57:18:94> GetDataFromDevice(): END
    57:19:95> GetDataFromDevice(): START
    57:20:47> GetDataFromDevice(): END
    57:21:47> GetDataFromDevice(): START
    57:21:99> GetDataFromDevice(): END
    57:22:08> Setup_Click(): END
    57:23:00> GetDataFromDevice(): START
    57:23:52> GetDataFromDevice(): END
    57:24:29> Setup_Click(): START
    57:24:30> GetNewPressure(): START
    57:24:51> GetDataFromDevice(): START
    57:25:04> GetDataFromDevice(): END
    57:26:03> GetDataFromDevice(): START
    57:26:55> GetDataFromDevice(): END
    57:27:62> Setup_Click(): END
    57:27:65> GetDataFromDevice(): START
    57:28:17> GetDataFromDevice(): END
    57:29:18> GetDataFromDevice(): START
    57:29:70> GetDataFromDevice(): END
    57:30:69> Setup_Click(): START
    57:30:70> GetNewPressure(): START
    57:30:85> GetDataFromDevice(): START
    57:31:37> GetDataFromDevice(): END
    57:32:37> GetDataFromDevice(): START
    57:32:89> GetDataFromDevice(): END
    57:33:89> GetDataFromDevice(): START
    57:34:41> GetDataFromDevice(): END
    57:34:42> Setup_Click(): END
    57:35:41> GetDataFromDevice(): START
    57:35:93> GetDataFromDevice(): END
    57:36:40> Setup_Click(): START
    57:36:40> GetNewPressure(): START
    57:36:92> GetDataFromDevice(): START
    57:37:43> GetDataFromDevice(): END
    57:38:45> GetDataFromDevice(): START
    57:38:97> GetDataFromDevice(): END
    57:39:97> GetDataFromDevice(): START
    57:40:48> GetDataFromDevice(): END
    57:41:48> GetDataFromDevice(): START
    57:42:01> GetDataFromDevice(): END
    57:42:02> Setup_Click(): END
    57:43:01> GetDataFromDevice(): START
    57:43:53> GetDataFromDevice(): END
    57:44:53> GetDataFromDevice(): START
    57:45:05> GetDataFromDevice(): END
    57:46:05> GetDataFromDevice(): START
    57:46:56> GetDataFromDevice(): END
    57:47:58> GetDataFromDevice(): START
    57:48:11> GetDataFromDevice(): END
    57:48:11> Setup_Click(): START
    57:49:11> GetDataFromDevice(): START
    57:49:63> GetDataFromDevice(): END
    57:49:65> Setup_Click(): END
    24:18:62> Click_Action(): CurrValue=2
    24:21:68> Click_Action(): CurrValue=1
    24:21:85> Click_Action(): CurrValue=2
    24:22:04> Click_Action(): CurrValue=3
    24:22:23> Click_Action(): CurrValue=4
    28:00:10> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    at tpms.tpms.GetDataFromDevice()(): The parameter is incorrect.<CR><LF>
    42:02:30> Click_Action(): CurrValue=2
    42:05:51> Click_Action(): CurrValue=1
    42:05:68> Click_Action(): CurrValue=2
    42:05:84> Click_Action(): CurrValue=3
    42:06:02> Click_Action(): CurrValue=4
    58:15:03> Click_Action(): CurrValue=5
    58:24:80> Click_Action(): CurrValue=2
    58:27:26> Click_Action(): CurrValue=1
    58:27:44> Click_Action(): CurrValue=2
    58:27:63> Click_Action(): CurrValue=3
    58:27:82> Click_Action(): CurrValue=4
    00:59:02> at tpms.tpms.GetDataFromDevice()(): Object reference not set to an instance of an object.
    01:21:64> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    01:28:99> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    01:36:73> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    01:44:02> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    01:51:53> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    01:59:02> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    02:06:64> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    02:14:05> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    02:21:65> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    02:29:28> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    02:36:66> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    02:44:02> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    02:51:41> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    02:59:10> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    03:06:48> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    03:14:30> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    03:21:73> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    03:29:32> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    03:36:71> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    03:44:32> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    03:51:67> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    03:58:99> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    04:06:69> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    04:14:11> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    04:21:54> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    04:29:04> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    04:36:94> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    04:44:31> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    04:51:50> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    04:59:39> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    05:07:04> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    05:14:04> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    05:21:46> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    05:29:15> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    05:36:64> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    05:44:11> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    05:51:54> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    05:59:16> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    06:06:56> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    06:14:01> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    06:21:49> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    06:29:34> at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
    Sep 2007
    This seems prevalent, however, I only have 3 working sensors right now, so maybe that's what the log is saying?
    "A device attached to the system is not functioning."
    Sep 2007
    bump...?
    Sep 2007
    I just replaced my 'bad' sensor with a brand new replacement from Portal Media...and it's not being 'read' by RRTMS either!
    Is there maybe something wrong with RRTMS and the front/right sensor programing?
    Sep 2007
    Okay, my fault...I forgot to change the sensor assignment to 'sensor 5' for that wheel...it's programmed now, BUT...
    I did a master reset on the board, and began relearning all the sensors. All of them are 'learned' now except my right rear!!
    This was the sensor that came detached from the stem and spent some time tumbling in my wheel...
    Is it destroyed?? It didn't look damaged...aren't the electronics expoxied? Think the battery came loose or something?
    Can the system be used with 2 'spare' sensors, if I have to replace another one?
    Lok
    Lok is offline
    VENDOR - Portal Media Lok's Avatar
    Feb 2008
    Sorry for leaving you hanging there. I know I answered this for you in an email but better to let everyone else know as well. Spare sensors and the sensors you get in your kit are identical. If you were to damage any one of your sensors you can replace it with a spare and relearn that particular sensor. The sensor is one solid piece with potting on the inside and the battery cannot be replaced, after about 5 years you will have to replace the actual sensors.
    Sep 2007
    Thanks Alok...
    I'm due for a set of tires shortly, so I might hit you up on yet another sensor...
    I'll be in touch.
    However, with me stuck with Vista, I can't make use of the current plugin
    Sep 2007
    Running XP SP3 now, and still getting the same random CF lockups as I did in Vista with the latest plugin...
    Lok
    Lok is offline
    Feb 2008
    Hmm, I am quite interested to know what is going on in particular with your system. There are now hundreds of users that are using this plug-in and device who have no issues at all. I know its kind of a stupid question but have you fully updated Centrafuse? I was having some lock up issues with the previous version of CF but not with the latest version.
  1. Centrafuse 2.0 Final
    By Jan_RedGTiVR6 in forum Centrafuse
    Last Post: 08-17-2008, 01:35 PM
  2. Centrafuse 2.0 RC4
    By veetid in forum Centrafuse
    Last Post: 06-10-2008, 09:31 PM
  3. Centrafuse 2.0 RC3
    By smeesseman in forum Centrafuse
    Last Post: 05-21-2008, 10:29 PM
  4. Centrafuse 2.0 RC2
    By Ogold007 in forum Centrafuse
    Last Post: 05-21-2008, 03:59 PM
  5. Centrafuse Vista Compatibility?
    By bns2000 in forum Centrafuse
    Last Post: 09-08-2007, 08:41 AM
